Hi there, I tried to add an OpenVPN connection via the gnome network manager.
Under Identity I get the following error “(Error: unable to load VPN connection editor)” I have installed all the bundles (network-basic, NetworkManager-extras) and that include packages required on other Linux distros.
Importing the ovpn config file still requires that I type in a username, and password which I cannot do.
running openvpn in the terminal also does not yield the desired results… I cannot connect to the VPN
