I tried to use boxes for another operating system, but it says that virtualization is not enabled in bios even though I did. Tried kvm before, but it is very confusing for me
- Check
/dev/kvmexists. It probably does. If not, something else may be wrong. - Check your userid is in the
kvmgroup. If not,sudo usermod -aG kvm $youruserid, then logout/login to make the change take effect.
The file does exist, but I’m just not familiar with typing commands because I used windows in the past. Can you give me an example of creating a virtual machine on kvm from scratch? Thanks
