I had to roll back to 37860. Same issue when I tried the 2021 LTS kernel. None of the wifi drivers would load and I lost video completely, including the virtual consoles. Ctrl-Alt-Delete did work to reboot. I’m using an AMD Radeon RX6700 XT video card in a new system with an Asus Prime Z790P Wifi motherboard and 13th gen core I7. I didn’t try the onboard video; that may have worked.
journalctl -r [snip]
Dec 27 18:52:48 mikePC2 kernel: [drm] amdgpu: ttm finalized
Dec 27 18:52:48 mikePC2 kernel: amdgpu: probe of 0000:03:00.0 failed with error -2
Dec 27 18:52:48 mikePC2 kernel: amdgpu 0000:03:00.0: amdgpu: amdgpu: finishing device.
Dec 27 18:52:48 mikePC2 kernel: input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:046D:C52>
Dec 27 18:52:48 mikePC2 kernel: input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:046D:C52B.0003/inpu>
Dec 27 18:52:48 mikePC2 kernel: amdgpu 0000:03:00.0: amdgpu: Fatal error during GPU init
Dec 27 18:52:48 mikePC2 kernel: hid-generic 0003:046D:C52B.0002: input,hidraw1: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14>
Dec 27 18:52:48 mikePC2 kernel: initcall rtl8169_pci_driver_init+0x0/0x1000 [r8169] returned 0 after 7892 usecs
Dec 27 18:52:48 mikePC2 kernel: initcall pcc_cpufreq_init+0x0/0xa9d [pcc_cpufreq] returned -17 after 0 usecs
Dec 27 18:52:48 mikePC2 kernel: calling pcc_cpufreq_init+0x0/0xa9d [pcc_cpufreq] @ 439
Dec 27 18:52:48 mikePC2 kernel: amdgpu 0000:03:00.0: amdgpu: amdgpu_device_ip_init failed
Dec 27 18:52:48 mikePC2 kernel: r8169 0000:08:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
Dec 27 18:52:48 mikePC2 kernel: [drm:amdgpu_device_ip_init [amdgpu]] ERROR sw_init of IP block failed -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-hr-b0-66
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-hr-b0-39
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: no suitable firmware found!
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-39.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-40.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-41.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-42.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-43.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-44.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-45.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-46.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-47.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-48.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-49.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-50.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-51.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-52.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-53.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-54.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-55.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-56.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-57.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-58.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-59.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-60.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-61.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-62.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-63.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-64.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-65.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-66.ucode failed with error -2
Dec 27 18:52:48 mikePC2 kernel: initcall iwl_drv_init+0x0/0x1000 [iwlwifi] returned 0 after 7557 usecs
Dec 27 18:52:48 mikePC2 kernel: r8169 0000:08:00.0 eth0: RTL8125B, c8:7f:54:59:22:2c, XID 641, IRQ 184
Dec 27 18:52:48 mikePC2 kernel: [drm:psp_sw_init [amdgpu]] ERROR Failed to load psp firmware!
Dec 27 18:52:48 mikePC2 kernel: iwlwifi 0000:00:14.3: enabling device (0000 → 0002)
Dec 27 18:52:48 mikePC2 kernel: amdgpu 0000:03:00.0: amdgpu: failed to init sos firmware
Dec 27 18:52:48 mikePC2 kernel: amdgpu 0000:03:00.0: Direct firmware load for amdgpu/navy_flounder_sos.bin failed with error -2
