I try to use physical android device in android studio wit my one plus 6t . I had no problems on Windows or ubuntu using the same laptop and phone (so it is not hardware or phone problem) , Android studio see my device yet do not recognize it as an Android device what can i do ?
You likely need to add the udev rules for the Android device to show up as a device for debugging. If I remember right, there is a community maintained repository on GitHub.
Thanks It worked ! If some will need links are here
