Environment: Apple Inc. MacPro6,1, Intel® Xeon® E5-1620 v2 × 8, 2 x AMD Radeon™ HD 7800 Series, nvme 2TB, destructive install, single OS, encryption enabled.
Tried the install of Clear Linux on my Apple Inc. MacPro6,1 2013 MacPro Trash Can from within the booted Clear Linux USB menu - install seemed to work without a hitch. However after successfully re-booting and entering the de-crypt password it boots into a lit up screen with a cursor looking bar in the top left corner (not blinking). Nothing else happens. I re-installed it twice with the same result.
Notable is that when performing the iso verification (usb live clear linux) it also failed verification as in fails to verify boot at some point. Running the clear linux compatibility scripts indicated all should be good to go. Hash signature of iso matched the 512 hash provided on the website. Also notable is that the life USB iso system boots fine and I can use Clear Linux via USB 2 (with some visual artifacts the gnome settings window when dragged around leaves a trail of windows and shows multiple overlapping shadow settings windows).
My guess is that it is likely due to some missing AMD GPU drivers since the the Gnome shell gdm3? cannot start properly.
<pre>00:00.0 Host bridge: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 DMI2 (rev 04)
00:01.0 PCI bridge: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 PCI Express Root Port 1a (rev 04)
00:02.0 PCI bridge: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 PCI Express Root Port 2a (rev 04)
00:03.0 PCI bridge: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 PCI Express Root Port 3a (rev 04)
00:04.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 0 (rev 04)
00:04.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 1 (rev 04)
00:04.2 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 2 (rev 04)
00:04.3 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 3 (rev 04)
00:04.4 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 4 (rev 04)
00:04.5 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 5 (rev 04)
00:04.6 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 6 (rev 04)
00:04.7 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Crystal Beach DMA Channel 7 (rev 04)
00:05.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 VTd/Memory Map/Misc (rev 04)
00:05.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Memory Hotplug (rev 04)
00:05.2 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 IIO RAS (rev 04)
00:05.4 PIC: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 IOAPIC (rev 04)
00:11.0 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Virtual Root Port (rev 06)
00:16.0 Communication controller: Intel Corporation C600/X79 series chipset MEI Controller #1 (rev 05)
00:1b.0 Audio device: Intel Corporation C600/X79 series chipset High Definition Audio Controller (rev 06)
00:1c.0 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 1 (rev b6)
00:1c.1 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 2 (rev b6)
00:1c.2 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 3 (rev b6)
00:1c.4 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 5 (rev b6)
00:1d.0 USB controller: Intel Corporation C600/X79 series chipset USB2 Enhanced Host Controller #1 (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation C600/X79 series chipset LPC Controller (rev 06)
00:1f.3 SMBus: Intel Corporation C600/X79 series chipset SMBus Host Controller (rev 06)
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tahiti LE [Radeon HD 7870 XT]
02:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Tahiti HDMI Audio [Radeon HD 7870 XT / 7950/7970]
06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tahiti LE [Radeon HD 7870 XT]
06:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Tahiti HDMI Audio [Radeon HD 7870 XT / 7950/7970]
0b:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM57762 Gigabit Ethernet PCIe
0c:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM57762 Gigabit Ethernet PCIe
0d:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter (rev 03)
0e:00.0 Non-Volatile memory controller: Sandisk Corp Western Digital WD Black SN850X NVMe SSD (rev 01)
10:00.0 PCI bridge: PLX Technology, Inc. Device 8723 (rev ca)
11:01.0 PCI bridge: PLX Technology, Inc. Device 8723 (rev ca)
11:02.0 PCI bridge: PLX Technology, Inc. Device 8723 (rev ca)
11:08.0 PCI bridge: PLX Technology, Inc. Device 8723 (rev ca)
11:09.0 PCI bridge: PLX Technology, Inc. Device 8723 (rev ca)
11:0a.0 PCI bridge: PLX Technology, Inc. Device 8723 (rev ca)
12:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10)
14:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
15:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
15:03.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
15:04.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
15:05.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
15:06.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
16:00.0 System peripheral: Intel Corporation DSL5520 Thunderbolt 2 NHI [Falcon Ridge 4C 2013]
17:00.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
18:03.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
18:04.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
18:05.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
19:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9182 PCIe 2.0 x2 2-port SATA 6 Gb/s Controller (rev 11)
5b:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
5c:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
5c:03.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
5c:04.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
5c:05.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
5c:06.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
5d:00.0 System peripheral: Intel Corporation DSL5520 Thunderbolt 2 NHI [Falcon Ridge 4C 2013]
5e:00.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
5f:00.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
5f:01.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
5f:02.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
5f:04.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
5f:05.0 PCI bridge: Intel Corporation CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
60:00.0 PCI bridge: Pericom Semiconductor Device 400c (rev 02)
61:03.0 PCI bridge: Pericom Semiconductor Device 400c (rev 02)
62:00.0 USB controller: Pericom Semiconductor PI7C9X442SL USB OHCI Controller (rev 01)
62:00.1 USB controller: Pericom Semiconductor PI7C9X442SL USB OHCI Controller (rev 01)
62:00.2 USB controller: Pericom Semiconductor PI7C9X442SL USB EHCI Controller (rev 03)
63:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM57761 Gigabit Ethernet PCIe (rev 10)
64:00.0 FireWire (IEEE 1394): LSI Corporation FW643 [TrueFire] PCIe 1394b Controller (rev 08)
80:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
81:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
81:01.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
81:02.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
81:03.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
81:04.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
82:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10)
83:00.0 USB controller: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller
84:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10)
85:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
86:00.0 USB controller: Intel Corporation JHL6540 Thunderbolt 3 USB Controller (C step) [Alpine Ridge 4C 2016] (rev 02)
a2:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a3:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a3:03.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a3:04.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a3:05.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a3:06.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a4:00.0 System peripheral: Intel Corporation DSL5520 Thunderbolt 2 NHI [Falcon Ridge 4C 2013]
a5:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a6:03.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a6:04.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a6:05.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
a7:00.0 SATA controller: ASMedia Technology Inc. 106x SATA/RAID Controller (rev 01)
ff:08.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Link 0 (rev 04)
ff:08.3 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Link Reut 0 (rev 04)
ff:08.4 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Link Reut 0 (rev 04)
ff:09.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Link 1 (rev 04)
ff:09.3 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Link 1 (rev 04)
ff:09.4 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Link Reut 1 (rev 04)
ff:0a.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Power Control Unit 0 (rev 04)
ff:0a.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Power Control Unit 1 (rev 04)
ff:0a.2 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Power Control Unit 2 (rev 04)
ff:0a.3 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Power Control Unit 3 (rev 04)
ff:0b.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 UBOX Registers (rev 04)
ff:0b.3 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 UBOX Registers (rev 04)
ff:0c.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Unicast Registers (rev 04)
ff:0c.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Unicast Registers (rev 04)
ff:0d.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Unicast Registers (rev 04)
ff:0d.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Unicast Registers (rev 04)
ff:0e.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Home Agent 0 (rev 04)
ff:0e.1 Performance counters: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Home Agent 0 (rev 04)
ff:0f.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 0 Target Address/Thermal Registers (rev 04)
ff:0f.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 0 RAS Registers (rev 04)
ff:0f.2 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers (rev 04)
ff:0f.3 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers (rev 04)
ff:0f.4 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers (rev 04)
ff:0f.5 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers (rev 04)
ff:0f.6 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 DDRIO Registers (rev 04)
ff:10.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 Thermal Control 0 (rev 04)
ff:10.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 Thermal Control 1 (rev 04)
ff:10.2 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 ERROR Registers 0 (rev 04)
ff:10.3 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 ERROR Registers 1 (rev 04)
ff:10.4 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 Thermal Control 2 (rev 04)
ff:10.5 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 Thermal Control 3 (rev 04)
ff:10.6 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 ERROR Registers 2 (rev 04)
ff:10.7 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Integrated Memory Controller 1 Channel 0-3 ERROR Registers 3 (rev 04)
ff:11.0 System peripheral: Intel Corporation Device 0eb8 (rev 04)
ff:13.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 R2PCIe (rev 04)
ff:13.1 Performance counters: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 R2PCIe (rev 04)
ff:13.4 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Ring Registers (rev 04)
ff:13.5 Performance counters: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Ring Performance Ring Monitoring (rev 04)
ff:13.6 Performance counters: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 QPI Ring Performance Ring Monitoring (rev 04)
ff:16.0 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 System Address Decoder (rev 04)
ff:16.1 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Broadcast Registers (rev 04)
ff:16.2 System peripheral: Intel Corporation Xeon E7 v2/Xeon E5 v2/Core i7 Broadcast Registers (rev 04)
</pre>
