Hi miguelinux and thanx for your help!
I used your method and the kernel line was added to the bootloader. A much better way than mine because I added it directly to the conf and the next clr-boot-manager update will wipe it.
Unfortunately the result after installing the nvidia driver was still the same white screen.
How can I be sure that the module is not loaded / used? I use
sudo lspci -vs 00:02.0
which gives me:
00:02.0 VGA compatible controller: Intel Corporation Device 3e94 (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 2269
Flags: bus master, fast devsel, latency 0, IRQ 130
Memory at 404a000000 (64-bit, non-prefetchable) [size=16M]
Memory at 80000000 (64-bit, prefetchable) [size=256M]
I/O ports at 3000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Kernel driver in use: i915
I interpret this that the driver i still in use. This
sudo lsmod | grep ^nvidia gives me:
nvidia_uvm 823296 0
nvidia_drm 45056 0
nvidia_modeset 1110016 1 nvidia_drm
nvidia 18767872 2 nvidia_uvm,nvidia_modeset
nvidiafb 53248 0
Any more Ideas? I really like clear linux but a non working nvidia setup is a showstopper for me.
Cheers
