I am struggling with finding the best performing remote desktop options for Clear. I have used NoMachine on other distros to good effect, and was mildly successful (with quite a few warts yet to work out) in getting it to work on Clear. I have never used Spice extensively, but would like to try it out, except a macOS client seems hard to come by. There are instructions at spice-space.org on building one and I have done that in the past but the client seems to be not well maintained.
I’ve also used xrdp, but performance there is not great. Are there other good performing options of which I am unaware?
I am also looking for a good remote desktop server to install on Clear Linux.
Have seen a vnc server part about it, but indeed is there a bundle for NoMachine?
So what is the best solution for Clear linux on this ?
TurboVNC is my favorite with fluid-like performance. Sound is lacking, but there’s a way and fluid as well. VNC Server is my next favorite. NoMachine is stable, no issues resizing.
If you’re in a place in your life wondering or tinkering, try out TurboVNC at least once. Way more fluid than xrdp. So so mind-boggling. Let your mind ponder on how that is possible.
