Eugene
July 19, 2022, 4:01pm
1
I am looking for ways to RDP to my would-be CL workstation from Windows.
Since ver 41, GNOME has included a remote desktop server exactly for such purposes, via RDP.
(And it does seem to work well in Ubuntu, without any hussle, as is).
(And is available as an rpm: https://fedora.pkgs.org/36/fedora-updates-aarch64/gnome-remote-desktop-42.3-1.fc36.aarch64.rpm.html )
Yet, it does not seem to be included into CL’s Gnome by default, nor could I find it in separate bundles/packs.
Would be great if this gets included.
If not, what are the practical alternatives? (i have looked on the forum but could not find a workable solution).
You might want to file a feature request at Issues · clearlinux/distribution · GitHub
Chris
Eugene
July 19, 2022, 6:22pm
3
Just did.
Hope including this isn’t too big of a deal.
Meanwhile, what are the RDP options?
nanon
July 20, 2022, 5:05pm
4
I reacted to your request on github.
This isn’t RDP, but currently I ssh in and run x11vnc. (Requires an x session obviously).
The nice thing about this is that I only run x11vnc while I’m using it.
Note that if you’re using the default GDM, you’ll need to already be logged in, or switch to an x-based login manager.
Eugene
July 20, 2022, 7:01pm
5
Thanks. I am looking for an RDP solution though.
nanon
July 20, 2022, 7:39pm
6
I hope it is added! I will use it.
Have you tried any of the FreeRDP based products like Remmina?
XRDP has also been suggested.
Eugene
July 22, 2022, 11:18am
8
Remmina is a client (=from which you connect).
xrdp still uses vnc under the hood; i couldn’t make it work anyway.
Any progress in this direction? The FreeRDP that comes with some of the CL bundles is pretty old, and doesn’t work with any RDP client. xrdp, on the other hand, seems pretty up to date.
Gorian
March 19, 2023, 4:25am
10
This isn’t necessarily true. There’s an option to use vnc, but iirc, there’s actually a plugin called xorgx11rdp which lets you use xrdp and plug directly into x11 without needing VNC.
