Hello everyone,
I recently recovered my old Chromebook ASUS C202SA, based on Braswell platform, and erased the Chromebook firmware in favour of a full EFI image
I’m facing an issue with the keyboard detection (trackpad works) on Clear Linux that I haven’t seen with other distribution like Manjaro or Ubuntu.
Basically at boot and when logged in in the Gnome environment, keyboard is simply “missing” and the only option is connecting an external one.
Now, since Clear Linux is visibly faster and more responsive than others, and this is the only issue with the entire system, I was wondering if there is a quick solution to address what is affecting the keyboard in CL, compared to other distros where it works out of the box, so I can keep CL on it.
I noticed that the full EFI image flash utility mentioned an issue with the keyboard if firmware <4.13 was used but CL is using 5.5.6 so we should be covered on that
Thanks
