which clames it to be fix in >30480, however I’m runniung 33000 with updates disabled…
But I’m not quite sure it my issue is the same - my startmenu is fine everything is where it should be but any file ask me, with what programm i like to openen it an shows me the empty app list
Works fine after installation, but maybe flathub breaks it?
Its just annoying…
trying to open a pdf, but happens with all filetypes
yes I know, but i have to run cuda and compile custom tensorflow versions you would go insane atleast I do, so I cannot see any advantage to have gcc10, just failed compiles and more stupid issues. However I’m sure I’ve saw this behavior with newer versions
