Hello guys!
First thank you for all the work into this distribution
I’m having some issues trying to run Clear Linux in a AWS instance after following your guide:
https://docs.01.org/clearlinux/latest/get-started/cloud-install/import-clr-aws.html
Where is the reference about the AWS_CLI group you are mentioning there?
Has anyone successfully imported a snapshot of clear linux using the docs recently?
Thanks again!
@madnexus - docs need a bit of work.
I suggest that you make an AWS Group, add the AWS pre-defined policy “AmazonEC2FullAccess” to the group. Next, attach the group to the IAM user you create.
Hi @mdpitterle
The user importing the snapshot is already in a group that has AmazonEC2FullAccess and AmazonS3FullAccess but I can’t get pass the following error message:
An error occurred (InvalidParameter) when calling the ImportSnapshot operation: User does not have access to the S3 object.(clear-linux-bucket/clear-33840-aws.img)
I have also attached a bucket policy in S3 giving the user access to the bucket with no luck.
[amazon web services - AWS Import-image User does not have access to the S3 object - Stack Overflow](https://AWS Import-image User does not have access to the S3 object)
Looks like getting Clear LInux on AWS is not as straightforward as it looked!
@madnexus - can you add VMImportExportRoleForAWSConnector policy to the group as well and try again?
Thanks for the help @mdpitterle
I have added it but still getting the same message. Have you imported one of the AWS ready images before?
