I have installed Clear several times with no problems in the past. My pc is a i3 10th gen desktop with a HD and nvme.I just downloaded the new 3500 version on usb and it would not install on my nvme, but did install on my HD. Shortly after the install starts it has a red dialog install failed see install log. I don’t understand the log.Any ideas? Could it just be the newer version? I’m dual booting with Windows 10. I tried the advanced partitioning and the along side selection.If so is older version available for download?
if that nvme is samsung 8xx or older there is likely to have some issue.
The NVME is a Western Digital PC SN520,less than 2 years old. I had some booting trouble after updating my Windows 10 to 21h1.I decided to just remove and reinstall Clear to solve it, but I got the installation failed warning. The install log has some lines mentioning partition warnings. As I said Clear has been installed on it before.
what’s the error message>
warning messages taken from clr-installer.log
2021/09/03 19:28:32 [WRN] Could not determine the guid for: nvme0n1p1
2021/09/03 19:28:32 [WRN] Could not determine the guid for: nvme0n1p2
2021/09/03 19:28:32 [WRN] Could not determine the guid for: nvme0n1p3
2021/09/03 19:28:32 [WRN] Could not determine the guid for: nvme0n1p4
2021/09/03 19:28:32 [WRN] Could not determine the guid for: nvme0n1p7
2021/09/03 19:28:40 [DBG] Warning: Partition(s) 1 on /dev/sdb have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
I was hoping someone could look at the log warnings and give me a clue as to why it installed to my HD fine but not to the SSD. I can post the whole clr-installer.log but the warnings were the only things that appeared wrong.
was this nvme partitioned as MBR?
I appreciate your replies but think someone who has had the same problem or can interpret the log is needed. My PC is less then 2 years old as in my original post,it’s EFI.
same issue here
MS Surface Laptop Go, nvme SSD.
it s been more than a week, we are at least 3 people with the issue and it seems like nobody has found a fix ??
PS : I made a bug report : Clear will not install to nvme with CLR_BOOT & CLR_ROOT partitions pre-prepared · Issue #2428 · clearlinux/distribution · GitHub …
oh it’s working when doing the installation alongside existing partitions !
(I previously had CLR_BOOT & CLR_ROOT partitions pre-prepared …)
(only had the issue that the ESP was not activated, see Can't Boot After Installation ? => Activate ESP (EFI) Partition in UEFI with bootctl install )
I am going to switch distros. I had hoped for some help,but nothing. I tried to read up on disk partioning , efi,esp and systemd -boot.I have to install it using several different methods. I have used Clear for over a year and liked its speed and reliability. Using a slow HHD when I have a fast ssd (a very common one, Western Digital PC SN520) is not fun.I believe the problem is in the installer but I am novice user, what do I know? I am very disappointed in the help from this forum.
We’re still waiting for your answer to Doct0rHu’s question:
“was this nvme partitioned as MBR?”
The partition is GPT. I would have replied to Doct0rHu question but I was sure all new pc’s were GPT now. Also I felt my original post was not read completely because my PC is too new to have a “old Samsung”. I stated Clear was installed before with no problems on the same PC, same partition table but the new updated 35000 download . Any help would still be appreciated. I will answer all questions in the future. Sorry and thanks
I ran fdisk -l to be sure there was no mistake that it is GPT
did you install alongside existing partitions ??
or did you pre-prepare CLR_BOOT and CLR_ROOT partitions ?
I tried both several times.
I also installed the bundle “clr-installer-gui” to the working HHD and tried to do the install from there instead of the USB. It failed both ways with that too.
Can you create the partitions with labels on your NVMe SSD manually and post your installer logs here? Also create new GPT table to be sure and/or use gdisk to check current table.
- CLR_BOOT (~200MB)
- CLR_SWAP (very small, 10-20MB)
- CLR_ROOT (30-40GB)
- CLR_MNT_/home (the rest)
From my experience new SSDs are clear.
2021/09/17 15:06:29 [INF] clr-installer-gui: 2.7.2-2-g9eac32df5b82, built on 2021-08-05_20:04:00_UTC
2021/09/17 15:06:29 [DBG] Loading config file: /tmp/clr-installer-noMedia-863539870.yaml
2021/09/17 15:06:29 [INF] Querying Clear Linux version
2021/09/17 15:06:29 [DBG] PrivateIP: Found IP: 52.38.183.78, Private IP?: false
2021/09/17 15:06:29 [DBG] PrivateIP: Found IP: 34.208.247.89, Private IP?: false
2021/09/17 15:06:29 [DBG] localectl list-keymaps --no-pager
2021/09/17 15:06:29 [DBG] Using default shellProxy.DefaultGetProxyValue
2021/09/17 15:06:29 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:29 [DBG] cmd.Env: []
2021/09/17 15:06:29 [DBG] timedatectl list-timezones
2021/09/17 15:06:29 [DBG] locale -a
2021/09/17 15:06:29 [DBG] Unable to use language locale 'agr_PE.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'ayc_PE.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'ber_DZ.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'ber_MA.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'bhb_IN.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'hne_IN.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'miq_NI.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'mjw_IN.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'mnw_MM.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'nhn_MX.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'shs_CA.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'the_NP.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'unm_US.UTF-8'
2021/09/17 15:06:29 [DBG] Unable to use language locale 'yuw_PG.UTF-8'
2021/09/17 15:06:29 [INF] Running system compatibility checks.
2021/09/17 15:06:29 [INF] Success: System is compatible
2021/09/17 15:06:29 [DBG] Launching MenuView
2021/09/17 15:06:29 [DBG] Before making ComboBox
2021/09/17 15:06:29 [DBG] partprobe -s
2021/09/17 15:06:31 [DBG] Warning: Partition(s) 1 on /dev/sdb have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2021/09/17 15:06:31 [DBG] /dev/sda: gpt partitions 1 3 2
2021/09/17 15:06:31 [DBG] /dev/sdb: msdos partitions 2
2021/09/17 15:06:31 [DBG] /dev/nvme0n1: gpt partitions 1 2 3 4 5 6
2021/09/17 15:06:31 [DBG] udevadm settle --timeout 10
2021/09/17 15:06:31 [DBG] Using default shellProxy.DefaultGetProxyValue
2021/09/17 15:06:31 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:31 [DBG] cmd.Env: []
2021/09/17 15:06:31 [DBG] lsblk --exclude 1,2,11 -J -b -O
2021/09/17 15:06:31 [DBG] parted --machine --script -- /dev/sda unit B print free
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "BYT"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "/dev/sda:1000204886016B:scsi:512:4096:gpt:ATA WDC WD10EZEX-60W:"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:17408B:157000191B:156982784B:fat32:EFI:boot, hidden, esp"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:157000192B:157286399B:286208B:free"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "3:157286400B:504101863423B:503944577024B:ext4:/:hidden"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:504101863424B:504102911999B:1048576B:free"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "2:504102912000B:1000204140543B:496101228544B:ntfs::msftdata"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:1000204140544B:1000204869119B:728576B:free"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is ""
2021/09/17 15:06:31 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print free
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "/dev/nvme0n1:128035676160B:nvme:512:512:gpt:WDC PC SN520 SDAPNUW-128G-1006:"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:17408B:1048575B:1031168B:free"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:1048576B:273678335B:272629760B:fat32:EFI system partition:boot, esp"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "2:273678336B:290455551B:16777216B::Microsoft reserved partition:msftres"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "3:290455552B:72077616127B:71787160576B:ntfs:Basic data partition:msftdata"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:72077616128B:72078065663B:449536B:free"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "4:72078065664B:72617033727B:538968064B:ntfs:Basic data partition:boot, hidden, esp"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "5:72617033728B:72826748927B:209715200B:fat32:CLR_BOOT:msftdata"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "6:72826748928B:115452411903B:42625662976B:f2fs:CLR_ROOT:"
2021/09/17 15:06:31 [DBG] setPartitionTable() line is "1:115452411904B:128035659263B:12583247360B:free"
2021/09/17 15:06:31 [DBG] buildMediaLists: Set DefaultSwapFileSize: 64MiB
2021/09/17 15:06:31 [DBG] FindSafeInstallTargets: Media sda does not have enough unallocated space minSize 18.8GiB
2021/09/17 15:06:31 [DBG] FindSafeInstallTargets: Media nvme0n1 does not have enough unallocated space minSize 18.8GiB
2021/09/17 15:06:31 [DBG] FindAllInstallTargets: found whole disk sda
2021/09/17 15:06:31 [DBG] FindAllInstallTargets: found whole disk nvme0n1
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition sda1 with name EFI
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition sda3 with name /
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p1 with name EFI system partition
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p2 with name Microsoft reserved partition
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p3 with name Basic data partition
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p4 with name Basic data partition
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p5 with name CLR_BOOT
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Partition label contains clr nvme0n1p5
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Boot is nvme0n1p5
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p6 with name CLR_ROOT
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: Root is nvme0n1p6
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p1 MappedName: Path:/dev/nvme0n1p1 Model: MajorMinor:259:1 PtType: FsType:vfat UUID:2CD2-5ED0 Serial: MountPoint: Label:SYSTEM PartitionLabel:EFI system partition Size:272629760 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:false Options: available:false partition:0 PartTable:[]}
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p2 MappedName: Path:/dev/nvme0n1p2 Model: MajorMinor:259:2 PtType: FsType: UUID: Serial: MountPoint: Label: PartitionLabel:Microsoft reserved partition Size:16777216 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:false Options: available:false partition:0 PartTable:[]}
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p3 MappedName: Path:/dev/nvme0n1p3 Model: MajorMinor:259:3 PtType: FsType:ntfs UUID:EADC1808DC17CE27 Serial: MountPoint: Label:Windows PartitionLabel:Basic data partition Size:71787160576 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:false Options: available:false partition:0 PartTable:[]}
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p4 MappedName: Path:/dev/nvme0n1p4 Model: MajorMinor:259:4 PtType: FsType:ntfs UUID:DC6880F26880CCA8 Serial: MountPoint: Label:Windows RE tools PartitionLabel:Basic data partition Size:538968064 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:false Options: available:false partition:0 PartTable:[]}
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p5 MappedName: Path:/dev/nvme0n1p5 Model: MajorMinor:259:5 PtType: FsType:vfat UUID:EEDC-711D Serial: MountPoint:/boot Label:BOOT PartitionLabel:CLR_BOOT Size:209715200 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:true Options: available:false partition:0 PartTable:[]}
2021/09/17 15:06:31 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p6 MappedName: Path:/dev/nvme0n1p6 Model: MajorMinor:259:6 PtType: FsType:f2fs UUID:72519020-e5df-45c3-85b2-f386bbc7bd65 Serial: MountPoint:/ Label:root PartitionLabel:CLR_ROOT Size:42625662976 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:true Options: available:false partition:0 PartTable:[]}
2021/09/17 15:06:31 [DBG] AddTargetMedia &{Name:nvme0n1 MappedName: Path:/dev/nvme0n1 Model:WDC PC SN520 SDAPNUW-128G-1006 MajorMinor:259:0 PtType: FsType: UUID: Serial:19525C804697 MountPoint: Label: PartitionLabel: Size:128035676160 Type:disk State:live ReadOnly:false RemovableDevice:false Children:[0xc0000ddcc0 0xc0000dde00 0xc0004da000 0xc0004da140 0xc0004da280 0xc0004da3c0] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:false Options: available:true partition:0 PartTable:[0xc0004c4500 0xc0004c45a0 0xc0004c45f0 0xc0004c4640 0xc0004c4690 0xc0004c4730 0xc0004c4780 0xc0004c47d0 0xc0004c4820]}
2021/09/17 15:06:31 [DBG] HasAdvancedSwap: false
2021/09/17 15:06:31 [DBG] validateAdvancedPartitions: Found partition nvme0n1p1 with name EFI system partition
2021/09/17 15:06:31 [DBG] validateAdvancedPartitions: Found partition nvme0n1p2 with name Microsoft reserved partition
2021/09/17 15:06:31 [DBG] validateAdvancedPartitions: Found partition nvme0n1p3 with name Basic data partition
2021/09/17 15:06:31 [DBG] validateAdvancedPartitions: Found partition nvme0n1p4 with name Basic data partition
2021/09/17 15:06:31 [DBG] validateAdvancedPartitions: Found partition nvme0n1p5 with name CLR_BOOT
2021/09/17 15:06:31 [DBG] validateAdvancedPartitions: Found partition nvme0n1p6 with name CLR_ROOT
2021/09/17 15:06:31 [DBG] Scanning media
2021/09/17 15:06:31 [DBG] partprobe -s
2021/09/17 15:06:31 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:31 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:32 [DBG] Warning: Partition(s) 1 on /dev/sdb have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2021/09/17 15:06:32 [DBG] /dev/sda: gpt partitions 1 3 2
2021/09/17 15:06:32 [DBG] /dev/sdb: msdos partitions 2
2021/09/17 15:06:32 [DBG] /dev/nvme0n1: gpt partitions 1 2 3 4 5 6
2021/09/17 15:06:32 [DBG] udevadm settle --timeout 10
2021/09/17 15:06:32 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:32 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:32 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:32 [DBG] cmd.Env: []
2021/09/17 15:06:32 [DBG] lsblk --exclude 1,2,11 -J -b -O
2021/09/17 15:06:32 [DBG] parted --machine --script -- /dev/sda unit B print free
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "BYT"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "/dev/sda:1000204886016B:scsi:512:4096:gpt:ATA WDC WD10EZEX-60W:"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:17408B:157000191B:156982784B:fat32:EFI:boot, hidden, esp"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:157000192B:157286399B:286208B:free"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "3:157286400B:504101863423B:503944577024B:ext4:/:hidden"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:504101863424B:504102911999B:1048576B:free"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "2:504102912000B:1000204140543B:496101228544B:ntfs::msftdata"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:1000204140544B:1000204869119B:728576B:free"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is ""
2021/09/17 15:06:32 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print free
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "/dev/nvme0n1:128035676160B:nvme:512:512:gpt:WDC PC SN520 SDAPNUW-128G-1006:"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:17408B:1048575B:1031168B:free"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:1048576B:273678335B:272629760B:fat32:EFI system partition:boot, esp"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "2:273678336B:290455551B:16777216B::Microsoft reserved partition:msftres"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "3:290455552B:72077616127B:71787160576B:ntfs:Basic data partition:msftdata"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:72077616128B:72078065663B:449536B:free"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "4:72078065664B:72617033727B:538968064B:ntfs:Basic data partition:boot, hidden, esp"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "5:72617033728B:72826748927B:209715200B:fat32:CLR_BOOT:msftdata"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "6:72826748928B:115452411903B:42625662976B:f2fs:CLR_ROOT:"
2021/09/17 15:06:32 [DBG] setPartitionTable() line is "1:115452411904B:128035659263B:12583247360B:free"
2021/09/17 15:06:34 [DBG] Partitions before sorting:
2021/09/17 15:06:34 [DBG] nvme0n1p1: fsType=vfat, mount=, size=272629760, type=part
2021/09/17 15:06:34 [DBG] nvme0n1p2: fsType=, mount=, size=16777216, type=part
2021/09/17 15:06:34 [DBG] nvme0n1p3: fsType=ntfs, mount=, size=71787160576, type=part
2021/09/17 15:06:34 [DBG] nvme0n1p4: fsType=ntfs, mount=, size=538968064, type=part
2021/09/17 15:06:34 [DBG] nvme0n1p5: fsType=vfat, mount=/boot, size=209715200, type=part
2021/09/17 15:06:34 [DBG] nvme0n1p6: fsType=f2fs, mount=/, size=42625662976, type=part
2021/09/17 15:06:34 [DBG] Partitions after sorting:
2021/09/17 15:06:34 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print
2021/09/17 15:06:34 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:34 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:34 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:34 [DBG] cmd.Env: []
2021/09/17 15:06:34 [DBG] MediaChange: nvme0n1: Selected media will be used for installation.
2021/09/17 15:06:34 [DBG] MediaChange: nvme0n1p5: Use existing partition. [/boot]
2021/09/17 15:06:34 [DBG] MediaChange: nvme0n1p6: Use existing partition. [/]
2021/09/17 15:06:34 [DBG] MediaChange: /var/swapfile (64MiB)
2021/09/17 15:06:41 [DBG] timeout --kill-after=30s 30s curl --no-sessionid -o /tmp/clr-installer-yaml-378246223 -s -f https://cdn.download.clearlinux.org/releases/35000/clear/config/image/.data/pre-gui-install-msg.yaml
2021/09/17 15:06:41 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:41 [INF] Running pre-install hooks
2021/09/17 15:06:41 [DBG] Clear Linux OS version: latest
2021/09/17 15:06:41 [DBG] WritePartitionTable: partial disk, skipping mklabel for nvme0n1
2021/09/17 15:06:41 [INF] Updating partition table for: nvme0n1
2021/09/17 15:06:41 [DBG] Partitions before sorting:
2021/09/17 15:06:41 [DBG] nvme0n1p1: fsType=vfat, mount=, size=272629760, type=part
2021/09/17 15:06:41 [DBG] nvme0n1p2: fsType=, mount=, size=16777216, type=part
2021/09/17 15:06:41 [DBG] nvme0n1p3: fsType=ntfs, mount=, size=71787160576, type=part
2021/09/17 15:06:41 [DBG] nvme0n1p4: fsType=ntfs, mount=, size=538968064, type=part
2021/09/17 15:06:41 [DBG] nvme0n1p5: fsType=vfat, mount=/boot, size=209715200, type=part
2021/09/17 15:06:41 [DBG] nvme0n1p6: fsType=f2fs, mount=/, size=42625662976, type=part
2021/09/17 15:06:41 [DBG] Partitions after sorting:
2021/09/17 15:06:41 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print
2021/09/17 15:06:41 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:41 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:41 [DBG] cmd.Env: []
2021/09/17 15:06:41 [DBG] WritePartitionTable: processing child: &{nvme0n1p1 /dev/nvme0n1p1 259:1 vfat 2CD2-5ED0 SYSTEM EFI system partition 272629760 part false false [] false false false false false 1 []}
2021/09/17 15:06:41 [DBG] WritePartitionTable: skipping partition nvme0n1p1
2021/09/17 15:06:41 [DBG] WritePartitionTable: processing child: &{nvme0n1p2 /dev/nvme0n1p2 259:2 Microsoft reserved partition 16777216 part false false [] false false false false false 2 []}
2021/09/17 15:06:41 [DBG] WritePartitionTable: skipping partition nvme0n1p2
2021/09/17 15:06:41 [DBG] WritePartitionTable: processing child: &{nvme0n1p3 /dev/nvme0n1p3 259:3 ntfs EADC1808DC17CE27 Windows Basic data partition 71787160576 part false false [] false false false false false 3 []}
2021/09/17 15:06:41 [DBG] WritePartitionTable: skipping partition nvme0n1p3
2021/09/17 15:06:41 [DBG] WritePartitionTable: processing child: &{nvme0n1p4 /dev/nvme0n1p4 259:4 ntfs DC6880F26880CCA8 Windows RE tools Basic data partition 538968064 part false false [] false false false false false 4 []}
2021/09/17 15:06:41 [DBG] WritePartitionTable: skipping partition nvme0n1p4
2021/09/17 15:06:41 [DBG] WritePartitionTable: processing child: &{nvme0n1p5 /dev/nvme0n1p5 259:5 vfat EEDC-711D /boot BOOT CLR_BOOT 209715200 part false false [] false false false true false 5 []}
2021/09/17 15:06:41 [DBG] WritePartitionTable: skipping partition nvme0n1p5
2021/09/17 15:06:41 [DBG] WritePartitionTable: processing child: &{nvme0n1p6 /dev/nvme0n1p6 259:6 f2fs 72519020-e5df-45c3-85b2-f386bbc7bd65 / root CLR_ROOT 42625662976 part false false [] false false false true false 6 []}
2021/09/17 15:06:41 [DBG] WritePartitionTable: skipping partition nvme0n1p6
2021/09/17 15:06:41 [WRN] Could not determine the guid for: nvme0n1p1
2021/09/17 15:06:41 [WRN] Could not determine the guid for: nvme0n1p2
2021/09/17 15:06:41 [WRN] Could not determine the guid for: nvme0n1p3
2021/09/17 15:06:41 [WRN] Could not determine the guid for: nvme0n1p4
2021/09/17 15:06:41 [INF] Setting GUIDs for device: /dev/nvme0n1
2021/09/17 15:06:41 [DBG] sgdisk /dev/nvme0n1 --typecode=5:C12A7328-F81F-11D2-BA4B-00A0C93EC93B
2021/09/17 15:06:42 [DBG] Pre-Installation has no message content
2021/09/17 15:06:42 [DBG] The operation has completed successfully.
2021/09/17 15:06:42 [DBG] sgdisk /dev/nvme0n1 --typecode=6:4F68BCE3-E8CD-4DB1-96E7-FBCAF984B709
2021/09/17 15:06:42 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:42 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:42 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:42 [DBG] cmd.Env: []
2021/09/17 15:06:43 [DBG] The operation has completed successfully.
2021/09/17 15:06:43 [INF] Setting boot partition: nvme0n1p5 [boot]
2021/09/17 15:06:43 [DBG] parted /dev/nvme0n1 set 5 boot on
2021/09/17 15:06:43 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:43 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:43 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:43 [DBG] cmd.Env: []
2021/09/17 15:06:43 [DBG] Information: You may need to update /etc/fstab.
2021/09/17 15:06:44 [DBG] partprobe /dev/nvme0n1
2021/09/17 15:06:44 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:44 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:44 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:44 [DBG] cmd.Env: []
2021/09/17 15:06:48 [DBG] Skipping new file system for nvme0n1p1
2021/09/17 15:06:48 [DBG] Skipping new file system for nvme0n1p2
2021/09/17 15:06:48 [DBG] Skipping new file system for nvme0n1p3
2021/09/17 15:06:48 [DBG] Skipping new file system for nvme0n1p4
2021/09/17 15:06:48 [DBG] Skipping new file system for nvme0n1p5
2021/09/17 15:06:48 [DBG] Skipping new file system for nvme0n1p6
2021/09/17 15:06:48 [DBG] partprobe -s
2021/09/17 15:06:48 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:48 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:48 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:48 [DBG] cmd.Env: []
2021/09/17 15:06:49 [DBG] Warning: Partition(s) 1 on /dev/sdb have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2021/09/17 15:06:49 [DBG] /dev/sda: gpt partitions 1 3 2
2021/09/17 15:06:49 [DBG] /dev/sdb: msdos partitions 2
2021/09/17 15:06:49 [DBG] /dev/nvme0n1: gpt partitions 1 2 3 4 5 6
2021/09/17 15:06:49 [DBG] udevadm settle --timeout 10
2021/09/17 15:06:49 [DBG] sync user is sudo_user=#1000
2021/09/17 15:06:49 [DBG] Gnome Proxy Mode: none
2021/09/17 15:06:49 [DBG] [Previous line repeated 4 times]
2021/09/17 15:06:49 [DBG] cmd.Env: []
2021/09/17 15:06:49 [DBG] lsblk --exclude 1,2,11 -J -b -O
2021/09/17 15:06:49 [DBG] parted --machine --script -- /dev/loop0 unit B print free
2021/09/17 15:06:49 [WRN] getPartitionTable() had an error reading partition table "Error: /dev/loop0: unrecognised disk label\nBYT;\n/dev/loop0:2894643200B:loopback:512:512:unknown:Loopback device:;\n"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is ""
2021/09/17 15:06:49 [DBG] parted --machine --script -- /dev/sda unit B print free
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "BYT"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "/dev/sda:1000204886016B:scsi:512:4096:gpt:ATA WDC WD10EZEX-60W:"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:17408B:157000191B:156982784B:fat32:EFI:boot, hidden, esp"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:157000192B:157286399B:286208B:free"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "3:157286400B:504101863423B:503944577024B:ext4:/:hidden"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:504101863424B:504102911999B:1048576B:free"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "2:504102912000B:1000204140543B:496101228544B:ntfs::msftdata"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:1000204140544B:1000204869119B:728576B:free"
2021/09/17 15:06:49 [DBG] parted --machine --script -- /dev/sdb unit B print free
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "/dev/sdb:17112760320B:scsi:512:512:msdos:PNY USB 3.0 FD:"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:1024B:69631B:68608B:free"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "2:69632B:104927231B:104857600B:fat16::esp"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:104927232B:17112760319B:17007833088B:free"
2021/09/17 15:06:49 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print free
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "/dev/nvme0n1:128035676160B:nvme:512:512:gpt:WDC PC SN520 SDAPNUW-128G-1006:"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:17408B:1048575B:1031168B:free"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:1048576B:273678335B:272629760B:fat32:EFI system partition:boot, esp"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "2:273678336B:290455551B:16777216B::Microsoft reserved partition:msftres"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "3:290455552B:72077616127B:71787160576B:ntfs:Basic data partition:msftdata"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:72077616128B:72078065663B:449536B:free"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "4:72078065664B:72617033727B:538968064B:ntfs:Basic data partition:boot, hidden, esp"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "5:72617033728B:72826748927B:209715200B:fat32:CLR_BOOT:boot, esp"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "6:72826748928B:115452411903B:42625662976B:f2fs:CLR_ROOT:"
2021/09/17 15:06:49 [DBG] setPartitionTable() line is "1:115452411904B:128035659263B:12583247360B:free"
2021/09/17 15:06:49 [INF] Mounting: /
2021/09/17 15:06:49 [INF] Running post-image hooks
2021/09/17 15:06:49 [INF] Installation Steps Complete
2021/09/17 15:06:49 [DBG] timeout --kill-after=30s 30s curl --no-sessionid -o /tmp/clr-installer-yaml-886823266 -s -f https://cdn.download.clearlinux.org/releases/35000/clear/config/image/.data/post-gui-install-msg.yaml
2021/09/17 15:06:49 [DBG] Post-Installation has no message content
I confirmed GPT using gnome disk manager. I let the installer create swap and did not use a home partion.```
