Part 2/2:
2025/05/16 23:26:45 [DBG] /usr/bin/ip route show
2025/05/16 23:26:45 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:26:45 [DBG] [Previous line repeated 4 times]
2025/05/16 23:26:45 [DBG] cmd.Env: []
2025/05/16 23:26:45 [DBG] /usr/bin/ip -j route show dev enp175s0
2025/05/16 23:26:45 [DBG] resolvectl --no-pager status enp175s0
2025/05/16 23:26:45 [DBG] Could not parse DNS Server nor Domain for enp175s0
2025/05/16 23:26:45 [DBG] /usr/bin/ip -j route show dev enp176s0
2025/05/16 23:26:45 [DBG] resolvectl --no-pager status enp176s0
2025/05/16 23:26:45 [DBG] Could not parse DNS Server for enp176s0
2025/05/16 23:26:45 [DBG] /usr/bin/ip -j route show dev wlp177s0
2025/05/16 23:26:45 [DBG] resolvectl --no-pager status wlp177s0
2025/05/16 23:26:45 [DBG] Could not parse DNS Server nor Domain for wlp177s0
2025/05/16 23:26:52 [DBG] proxy.SetHTTPSProxy =
2025/05/16 23:26:54 [INF] Testing connectivity
2025/05/16 23:26:54 [DBG] /usr/bin/timeout --kill-after=10s 10s /usr/bin/curl --no-sessionid -o /dev/null -s -f https://cdn.download.clearlinux.org/update/
2025/05/16 23:26:54 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:26:54 [DBG] [Previous line repeated 4 times]
2025/05/16 23:26:54 [DBG] cmd.Env: []
2025/05/16 23:26:58 [DBG] Partitions before sorting:
2025/05/16 23:26:58 [DBG] nvme0n1p1: fsType=vfat, mount=, size=104857600, type=part
2025/05/16 23:26:58 [DBG] nvme0n1p2: fsType=, mount=, size=134217728, type=part
2025/05/16 23:26:58 [DBG] nvme0n1p3: fsType=ntfs, mount=, size=79404466176, type=part
2025/05/16 23:26:58 [DBG] nvme0n1p4: fsType=ntfs, mount=, size=1814036480, type=part
2025/05/16 23:26:58 [DBG] nvme0n1p5: fsType=ext4, mount=, size=256295043072, type=part
2025/05/16 23:26:58 [DBG] nvme0n1p6: fsType=ext4, mount=/, size=164911644672, type=part
2025/05/16 23:26:58 [DBG] nvme0n1p7: fsType=swap, mount=, size=8370782208, type=part
2025/05/16 23:26:58 [DBG] nvme0n1p8: fsType=vfat, mount=/boot, size=1073741824, type=part
2025/05/16 23:26:58 [DBG] Partitions after sorting:
2025/05/16 23:26:58 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print
2025/05/16 23:26:58 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:26:58 [DBG] [Previous line repeated 4 times]
2025/05/16 23:26:58 [DBG] cmd.Env: []
2025/05/16 23:26:58 [DBG] MediaChange: nvme0n1: Selected media will be used for installation.
2025/05/16 23:26:58 [DBG] MediaChange: nvme0n1p6: Use existing partition. [/]
2025/05/16 23:26:58 [DBG] MediaChange: nvme0n1p7: Use existing partition. (swap)
2025/05/16 23:26:58 [DBG] MediaChange: nvme0n1p8: Use existing partition. [/boot]
2025/05/16 23:27:03 [DBG] timeout --kill-after=30s 30s curl --no-sessionid -o /tmp/clr-installer-yaml-1531194700 -s -f https://cdn.download.clearlinux.org/releases/43470/clear/config/image/.data/pre-install-msg.yaml
2025/05/16 23:27:03 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:27:03 [DBG] [Previous line repeated 4 times]
2025/05/16 23:27:03 [DBG] cmd.Env: []
2025/05/16 23:27:03 [INF] Running pre-install hooks
2025/05/16 23:27:03 [DBG] Clear Linux OS version: latest
2025/05/16 23:27:03 [DBG] WritePartitionTable: partial disk, skipping mklabel for nvme0n1
2025/05/16 23:27:03 [INF] Updating partition table for: nvme0n1
2025/05/16 23:27:03 [DBG] Partitions before sorting:
2025/05/16 23:27:03 [DBG] nvme0n1p1: fsType=vfat, mount=, size=104857600, type=part
2025/05/16 23:27:03 [DBG] nvme0n1p2: fsType=, mount=, size=134217728, type=part
2025/05/16 23:27:03 [DBG] nvme0n1p3: fsType=ntfs, mount=, size=79404466176, type=part
2025/05/16 23:27:03 [DBG] nvme0n1p4: fsType=ntfs, mount=, size=1814036480, type=part
2025/05/16 23:27:03 [DBG] nvme0n1p5: fsType=ext4, mount=, size=256295043072, type=part
2025/05/16 23:27:03 [DBG] nvme0n1p6: fsType=ext4, mount=/, size=164911644672, type=part
2025/05/16 23:27:03 [DBG] nvme0n1p7: fsType=swap, mount=, size=8370782208, type=part
2025/05/16 23:27:03 [DBG] nvme0n1p8: fsType=vfat, mount=/boot, size=1073741824, type=part
2025/05/16 23:27:03 [DBG] Partitions after sorting:
2025/05/16 23:27:03 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p1 /dev/nvme0n1p1 259:1 vfat 1677-CF9C EFI_BOOT EFI system partition 104857600 part false false [] false false false false false 1 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p1
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p2 /dev/nvme0n1p2 259:2 Microsoft reserved partition 134217728 part false false [] false false false false false 2 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p2
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p3 /dev/nvme0n1p3 259:3 ntfs F04078D54078A3CE Win 11 Pro x64 Basic data partition 79404466176 part false false [] false false false false false 3 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p3
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p4 /dev/nvme0n1p4 259:4 ntfs 8ADC2001DC1FE66B Recovery Basic data partition 1814036480 part false false [] false false false false false 4 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p4
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p5 /dev/nvme0n1p5 259:5 ext4 87881280-677f-4dcd-bd64-7dddbafad4d3 home CLR_HOME 256295043072 part false false [] false false false false false 5 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p5
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p6 /dev/nvme0n1p6 259:6 ext4 b32c036b-bad6-4a15-aa8e-72132c24282f / root CLR_ROOT 164911644672 part false false [] false false false true false 6 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p6
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p7 /dev/nvme0n1p7 259:7 swap 087ccf17-b00e-4f28-a585-de71481e1405 CLR_SWAP 8370782208 part false false [] false false false true false 7 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p7
2025/05/16 23:27:03 [DBG] WritePartitionTable: processing child: &{nvme0n1p8 /dev/nvme0n1p8 259:8 vfat 56F1-8263 /boot BOOT CLR_BOOT 1073741824 part false false [] false false false true false 8 []}
2025/05/16 23:27:03 [DBG] WritePartitionTable: skipping partition nvme0n1p8
2025/05/16 23:27:03 [WRN] Could not determine the guid for: nvme0n1p1
2025/05/16 23:27:03 [WRN] Could not determine the guid for: nvme0n1p2
2025/05/16 23:27:03 [WRN] Could not determine the guid for: nvme0n1p3
2025/05/16 23:27:03 [WRN] Could not determine the guid for: nvme0n1p4
2025/05/16 23:27:03 [WRN] Could not determine the guid for: nvme0n1p5
2025/05/16 23:27:03 [INF] Setting GUIDs for device: /dev/nvme0n1
2025/05/16 23:27:03 [DBG] sgdisk /dev/nvme0n1 --typecode=6:4F68BCE3-E8CD-4DB1-96E7-FBCAF984B709
2025/05/16 23:27:03 [DBG] Pre-Installation has no message content
2025/05/16 23:27:04 [DBG] The operation has completed successfully.
2025/05/16 23:27:04 [DBG] sgdisk /dev/nvme0n1 --typecode=7:0657FD6D-A4AB-43C4-84E5-0933C84B4F4F
2025/05/16 23:27:04 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:27:04 [DBG] [Previous line repeated 4 times]
2025/05/16 23:27:04 [DBG] cmd.Env: []
2025/05/16 23:27:05 [DBG] The operation has completed successfully.
2025/05/16 23:27:05 [DBG] sgdisk /dev/nvme0n1 --typecode=8:C12A7328-F81F-11D2-BA4B-00A0C93EC93B
2025/05/16 23:27:05 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:27:05 [DBG] [Previous line repeated 4 times]
2025/05/16 23:27:05 [DBG] cmd.Env: []
2025/05/16 23:27:06 [DBG] The operation has completed successfully.
2025/05/16 23:27:07 [INF] Setting boot partition: nvme0n1p8 [boot]
2025/05/16 23:27:07 [DBG] parted /dev/nvme0n1 set 8 boot on
2025/05/16 23:27:07 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:27:07 [DBG] [Previous line repeated 4 times]
2025/05/16 23:27:07 [DBG] cmd.Env: []
2025/05/16 23:27:07 [DBG] Information: You may need to update /etc/fstab.
2025/05/16 23:27:09 [DBG] partprobe /dev/nvme0n1
2025/05/16 23:27:09 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:27:09 [DBG] [Previous line repeated 4 times]
2025/05/16 23:27:09 [DBG] cmd.Env: []
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p1
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p2
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p3
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p4
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p5
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p6
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p7
2025/05/16 23:27:13 [DBG] Skipping new file system for nvme0n1p8
2025/05/16 23:27:13 [DBG] partprobe -s
2025/05/16 23:27:13 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:27:13 [DBG] [Previous line repeated 4 times]
2025/05/16 23:27:13 [DBG] cmd.Env: []
2025/05/16 23:27:14 [DBG] Warning: Partition(s) 1 on /dev/sda have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2025/05/16 23:27:14 [DBG] /dev/sda: msdos partitions 2
2025/05/16 23:27:14 [DBG] /dev/nvme0n1: gpt partitions 1 2 3 8 6 7 5 4
2025/05/16 23:27:14 [DBG] udevadm settle --timeout 10
2025/05/16 23:27:14 [DBG] Using default shellProxy.DefaultGetProxyValue
2025/05/16 23:27:14 [DBG] [Previous line repeated 4 times]
2025/05/16 23:27:14 [DBG] cmd.Env: []
2025/05/16 23:27:14 [DBG] lsblk --exclude 1,2,11 -J -b -O
2025/05/16 23:27:14 [DBG] parted --machine --script -- /dev/loop0 unit B print free
2025/05/16 23:27:14 [WRN] getPartitionTable() had an error reading partition table "Error: /dev/loop0: unrecognised disk label\nBYT;\n/dev/loop0:2307035136B:loopback:512:512:unknown:Loopback device:;\n"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is ""
2025/05/16 23:27:14 [DBG] parted --machine --script -- /dev/sda unit B print free
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "BYT"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "/dev/sda:15502147584B:scsi:512:512:msdos:Kingston DataTraveler 3.0:"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "1:1024B:69631B:68608B:free"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "2:69632B:268505087B:268435456B:fat16::esp"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "1:268505088B:15502147583B:15233642496B:free"
2025/05/16 23:27:14 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print free
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "/dev/nvme0n1:512110190592B:nvme:512:512:gpt:VICKTER NVMe:"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "1:17408B:1048575B:1031168B:free"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "1:1048576B:105906175B:104857600B:fat32:EFI system partition:boot, esp, no_automount"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "2:105906176B:240123903B:134217728B::Microsoft reserved partition:msftres, no_automount"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "3:240123904B:79644590079B:79404466176B:ntfs:Basic data partition:msftdata"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "8:79644590080B:80718331903B:1073741824B:fat32:CLR_BOOT:boot, esp"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "6:80718331904B:245629976575B:164911644672B:ext4:CLR_ROOT:"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "7:245629976576B:254000758783B:8370782208B:linux-swap(v1):CLR_SWAP:swap"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "5:254000758784B:510295801855B:256295043072B:ext4:CLR_HOME:linux-home"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "4:510295801856B:512109838335B:1814036480B:ntfs:Basic data partition:hidden, diag, no_automount"
2025/05/16 23:27:14 [DBG] setPartitionTable() line is "1:512109838336B:512110173695B:335360B:free"
2025/05/16 23:27:14 [INF] Mounting: /
2025/05/16 23:27:14 [INF] Running post-image hooks
2025/05/16 23:27:14 [INF] Installation Steps Complete
2025/05/16 23:27:14 [ERR]
Error Trace:
storage.mountFs()
/builddir/build/BUILD/clr-installer-2.7.15/storage/utils.go:34
storage.(*BlockDevice).Mount()
/builddir/build/BUILD/clr-installer-2.7.15/storage/block_devices_ops.go:283
mount /dev/nvme0n1p6 /tmp/install-4105778781 ext4: no such file or directory
2025/05/16 23:27:14 [WRN] Telemetry is not present in the installer, skip record generation
2025/05/16 23:27:14 [DBG] dmesg --console-on
2025/05/16 23:27:14 [ERR] mount /dev/nvme0n1p6 /tmp/install-4105778781 ext4: no such file or directory
Error Trace:
storage.mountFs()
