It failed in multiple attempts.
I tried both destructive method and advanced.
2021/11/23 02:37:42 [DBG] Log Level set to LogLevelDebug (4)
2021/11/23 02:37:42 [INF] clr-installer-gui: 2.7.2-2-g9eac32df5b82, built on 2021-08-05_20:04:00_UTC
2021/11/23 02:37:42 [DBG] Loading config file: /tmp/clr-installer-noMedia-606159565.yaml
2021/11/23 02:37:42 [INF] Querying Clear Linux version
2021/11/23 02:37:43 [DBG] PrivateIP: Found IP: 35.165.138.86, Private IP?: false
2021/11/23 02:37:43 [DBG] PrivateIP: Found IP: 52.41.57.104, Private IP?: false
2021/11/23 02:37:43 [DBG] localectl list-keymaps --no-pager
2021/11/23 02:37:43 [DBG] Using default shellProxy.DefaultGetProxyValue
2021/11/23 02:37:43 [DBG] [Previous line repeated 4 times]
2021/11/23 02:37:43 [DBG] cmd.Env: []
2021/11/23 02:37:43 [DBG] timedatectl list-timezones
2021/11/23 02:37:43 [DBG] locale -a
2021/11/23 02:37:43 [DBG] Unable to use language locale 'agr_PE.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'ayc_PE.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'ber_DZ.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'ber_MA.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'bhb_IN.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'hne_IN.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'miq_NI.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'mjw_IN.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'mnw_MM.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'nhn_MX.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'shs_CA.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'the_NP.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'unm_US.UTF-8'
2021/11/23 02:37:43 [DBG] Unable to use language locale 'yuw_PG.UTF-8'
2021/11/23 02:37:43 [INF] Running system compatibility checks.
2021/11/23 02:37:43 [INF] Success: System is compatible
2021/11/23 02:37:43 [DBG] Launching MenuView
2021/11/23 02:37:43 [DBG] Before making ComboBox
2021/11/23 02:37:43 [DBG] partprobe -s
2021/11/23 02:37:44 [DBG] Warning: Partition(s) 1 on /dev/sda have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2021/11/23 02:37:44 [DBG] /dev/sda: msdos partitions 2
2021/11/23 02:37:44 [DBG] /dev/nvme0n1: gpt partitions 1 2
2021/11/23 02:37:44 [DBG] udevadm settle --timeout 10
2021/11/23 02:37:44 [DBG] Using default shellProxy.DefaultGetProxyValue
2021/11/23 02:37:44 [DBG] [Previous line repeated 4 times]
2021/11/23 02:37:44 [DBG] cmd.Env: []
2021/11/23 02:37:44 [DBG] lsblk --exclude 1,2,11 -J -b -O
2021/11/23 02:37:44 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print free
2021/11/23 02:37:44 [DBG] setPartitionTable() line is "BYT"
2021/11/23 02:37:44 [DBG] setPartitionTable() line is "/dev/nvme0n1:512110190592B:nvme:512:512:gpt:INTEL SSDPEKNW512G8H:"
2021/11/23 02:37:44 [DBG] setPartitionTable() line is "1:17408B:1048575B:1031168B:free"
2021/11/23 02:37:44 [DBG] setPartitionTable() line is "1:1048576B:1073741823B:1072693248B:fat32:CLR_BOOT:msftdata"
2021/11/23 02:37:44 [DBG] setPartitionTable() line is "2:1073741824B:512109838335B:511036096512B:ext4:CLR_ROOT:"
2021/11/23 02:37:44 [DBG] setPartitionTable() line is "1:512109838336B:512110173695B:335360B:free"
2021/11/23 02:37:44 [DBG] setPartitionTable() line is ""
2021/11/23 02:37:44 [DBG] buildMediaLists: Set DefaultSwapFileSize: 64MiB
2021/11/23 02:37:44 [DBG] FindSafeInstallTargets: Media nvme0n1 does not have enough unallocated space minSize 18.8GiB
2021/11/23 02:37:44 [DBG] FindAllInstallTargets: found whole disk nvme0n1
2021/11/23 02:37:44 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p1 with name CLR_BOOT
2021/11/23 02:37:44 [DBG] FindAdvancedInstallTargets: Partition label contains clr nvme0n1p1
2021/11/23 02:37:44 [DBG] FindAdvancedInstallTargets: Boot is nvme0n1p1
2021/11/23 02:37:44 [DBG] FindAdvancedInstallTargets: Found partition nvme0n1p2 with name CLR_ROOT
2021/11/23 02:37:44 [DBG] FindAdvancedInstallTargets: Root is nvme0n1p2
2021/11/23 02:37:44 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p1 MappedName: Path:/dev/nvme0n1p1 Model: MajorMinor:259:1 PtType: FsType:vfat UUID:3E77-730B Serial: MountPoint:/boot Label:BOOT PartitionLabel:CLR_BOOT Size:1072693248 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:true Options: available:false partition:0 PartTable:[]}
2021/11/23 02:37:44 [DBG] FindAdvancedInstallTargets: child: &{Name:nvme0n1p2 MappedName: Path:/dev/nvme0n1p2 Model: MajorMinor:259:2 PtType: FsType:ext4 UUID:113407e1-db31-4c05-8e98-762c25a51e13 Serial: MountPoint:/ Label:root PartitionLabel:CLR_ROOT Size:511036096512 Type:part State: ReadOnly:false RemovableDevice:false Children:[] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:true Options: available:false partition:0 PartTable:[]}
2021/11/23 02:37:44 [DBG] AddTargetMedia &{Name:nvme0n1 MappedName: Path:/dev/nvme0n1 Model:INTEL SSDPEKNW512G8H MajorMinor:259:0 PtType: FsType: UUID: Serial:PHNH9331044E512A MountPoint: Label: PartitionLabel: Size:512110190592 Type:disk State:live ReadOnly:false RemovableDevice:false Children:[0xc0002c2c80 0xc0002c2dc0] UserDefined:false MakePartition:false FormatPartition:false LabeledAdvanced:false Options: available:true partition:0 PartTable:[0xc0004860f0 0xc000486190 0xc0004861e0 0xc000486230]}
2021/11/23 02:37:44 [DBG] HasAdvancedSwap: false
2021/11/23 02:37:44 [DBG] validateAdvancedPartitions: Found partition nvme0n1p1 with name CLR_BOOT
2021/11/23 02:37:44 [DBG] validateAdvancedPartitions: Found partition nvme0n1p2 with name CLR_ROOT
2021/11/23 02:37:44 [DBG] Scanning media
2021/11/23 02:37:44 [DBG] partprobe -s
2021/11/23 02:37:44 [DBG] sync user is sudo_user=#1000
2021/11/23 02:37:44 [DBG] Gnome Proxy Mode: none
2021/11/23 02:37:45 [DBG] Warning: Partition(s) 1 on /dev/sda have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2021/11/23 02:37:45 [DBG] /dev/sda: msdos partitions 2
2021/11/23 02:37:45 [DBG] /dev/nvme0n1: gpt partitions 1 2
2021/11/23 02:37:45 [DBG] udevadm settle --timeout 10
2021/11/23 02:37:45 [DBG] sync user is sudo_user=#1000
2021/11/23 02:37:45 [DBG] Gnome Proxy Mode: none
2021/11/23 02:37:45 [DBG] [Previous line repeated 4 times]
2021/11/23 02:37:45 [DBG] cmd.Env: []
2021/11/23 02:37:45 [DBG] lsblk --exclude 1,2,11 -J -b -O
2021/11/23 02:37:45 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print free
2021/11/23 02:37:45 [DBG] setPartitionTable() line is "BYT"
2021/11/23 02:37:45 [DBG] setPartitionTable() line is "/dev/nvme0n1:512110190592B:nvme:512:512:gpt:INTEL SSDPEKNW512G8H:"
2021/11/23 02:37:45 [DBG] setPartitionTable() line is "1:17408B:1048575B:1031168B:free"
2021/11/23 02:37:45 [DBG] setPartitionTable() line is "1:1048576B:1073741823B:1072693248B:fat32:CLR_BOOT:msftdata"
2021/11/23 02:37:45 [DBG] setPartitionTable() line is "2:1073741824B:512109838335B:511036096512B:ext4:CLR_ROOT:"
2021/11/23 02:37:45 [DBG] setPartitionTable() line is "1:512109838336B:512110173695B:335360B:free"
2021/11/23 02:37:45 [DBG] setPartitionTable() line is ""
2021/11/23 02:37:46 [DBG] Starting in addMode
2021/11/23 02:37:54 [DBG] /usr/bin/cracklib-check
2021/11/23 02:37:54 [DBG] sync user is sudo_user=#1000
2021/11/23 02:37:54 [DBG] Gnome Proxy Mode: none
2021/11/23 02:37:54 [DBG] [Previous line repeated 4 times]
2021/11/23 02:37:54 [DBG] cmd.Env: []
2021/11/23 02:37:55 [DBG] /usr/bin/cracklib-check
2021/11/23 02:37:55 [DBG] sync user is sudo_user=#1000
2021/11/23 02:37:55 [DBG] Gnome Proxy Mode: none
2021/11/23 02:37:55 [DBG] [Previous line repeated 4 times]
2021/11/23 02:37:55 [DBG] cmd.Env: []
2021/11/23 02:37:57 [DBG] page.model.Users[0]: &{Login:android UserName:android Password: Admin:true SSHKeys:[]}
2021/11/23 02:38:17 [DBG] Partitions before sorting:
2021/11/23 02:38:17 [DBG] nvme0n1p1: fsType=vfat, mount=/boot, size=1072693248, type=part
2021/11/23 02:38:17 [DBG] nvme0n1p2: fsType=ext4, mount=/, size=511036096512, type=part
2021/11/23 02:38:17 [DBG] Partitions after sorting:
2021/11/23 02:38:17 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print
2021/11/23 02:38:17 [DBG] sync user is sudo_user=#1000
2021/11/23 02:38:17 [DBG] Gnome Proxy Mode: none
2021/11/23 02:38:17 [DBG] [Previous line repeated 4 times]
2021/11/23 02:38:17 [DBG] cmd.Env: []
2021/11/23 02:38:17 [DBG] MediaChange: nvme0n1: Selected media will be used for installation.
2021/11/23 02:38:17 [DBG] MediaChange: nvme0n1p1: Use existing partition. [/boot]
2021/11/23 02:38:17 [DBG] MediaChange: nvme0n1p2: Use existing partition. [/]
2021/11/23 02:38:17 [DBG] MediaChange: /var/swapfile (64MiB)
2021/11/23 02:38:23 [DBG] timeout --kill-after=30s 30s curl --no-sessionid -o /tmp/clr-installer-yaml-862023265 -s -f https://cdn.download.clearlinux.org/releases/35000/clear/config/image/.data/pre-gui-install-msg.yaml
2021/11/23 02:38:23 [DBG] sync user is sudo_user=#1000
2021/11/23 02:38:23 [INF] Running pre-install hooks
2021/11/23 02:38:23 [DBG] Clear Linux OS version: latest
2021/11/23 02:38:23 [DBG] WritePartitionTable: partial disk, skipping mklabel for nvme0n1
2021/11/23 02:38:23 [INF] Updating partition table for: nvme0n1
2021/11/23 02:38:23 [DBG] Partitions before sorting:
2021/11/23 02:38:23 [DBG] nvme0n1p1: fsType=vfat, mount=/boot, size=1072693248, type=part
2021/11/23 02:38:23 [DBG] nvme0n1p2: fsType=ext4, mount=/, size=511036096512, type=part
2021/11/23 02:38:23 [DBG] Partitions after sorting:
2021/11/23 02:38:23 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print
2021/11/23 02:38:23 [DBG] Gnome Proxy Mode: none
2021/11/23 02:38:23 [DBG] [Previous line repeated 4 times]
2021/11/23 02:38:23 [DBG] cmd.Env: []
2021/11/23 02:38:23 [DBG] WritePartitionTable: processing child: &{nvme0n1p1 /dev/nvme0n1p1 259:1 vfat 3E77-730B /boot BOOT CLR_BOOT 1072693248 part false false [] false false false true false 1 []}
2021/11/23 02:38:23 [DBG] WritePartitionTable: skipping partition nvme0n1p1
2021/11/23 02:38:23 [DBG] WritePartitionTable: processing child: &{nvme0n1p2 /dev/nvme0n1p2 259:2 ext4 113407e1-db31-4c05-8e98-762c25a51e13 / root CLR_ROOT 511036096512 part false false [] false false false true false 2 []}
2021/11/23 02:38:23 [DBG] WritePartitionTable: skipping partition nvme0n1p2
2021/11/23 02:38:23 [INF] Setting GUIDs for device: /dev/nvme0n1
2021/11/23 02:38:23 [DBG] sgdisk /dev/nvme0n1 --typecode=1:C12A7328-F81F-11D2-BA4B-00A0C93EC93B
2021/11/23 02:38:24 [DBG] The operation has completed successfully.
2021/11/23 02:38:24 [DBG] sgdisk /dev/nvme0n1 --typecode=2:4F68BCE3-E8CD-4DB1-96E7-FBCAF984B709
2021/11/23 02:38:24 [DBG] sync user is sudo_user=#1000
2021/11/23 02:38:24 [DBG] Gnome Proxy Mode: none
2021/11/23 02:38:24 [DBG] [Previous line repeated 4 times]
2021/11/23 02:38:24 [DBG] cmd.Env: []
2021/11/23 02:38:25 [DBG] The operation has completed successfully.
2021/11/23 02:38:25 [INF] Setting boot partition: nvme0n1p1 [boot]
2021/11/23 02:38:25 [DBG] parted /dev/nvme0n1 set 1 boot on
2021/11/23 02:38:25 [DBG] sync user is sudo_user=#1000
2021/11/23 02:38:25 [DBG] Gnome Proxy Mode: none
2021/11/23 02:38:25 [DBG] [Previous line repeated 4 times]
2021/11/23 02:38:25 [DBG] cmd.Env: []
2021/11/23 02:38:25 [DBG] Information: You may need to update /etc/fstab.
2021/11/23 02:38:25 [DBG] partprobe /dev/nvme0n1
2021/11/23 02:38:29 [DBG] Skipping new file system for nvme0n1p1
2021/11/23 02:38:29 [DBG] Skipping new file system for nvme0n1p2
2021/11/23 02:38:29 [DBG] partprobe -s
2021/11/23 02:38:29 [DBG] sync user is sudo_user=#1000
2021/11/23 02:38:29 [DBG] Gnome Proxy Mode: none
2021/11/23 02:38:29 [DBG] [Previous line repeated 4 times]
2021/11/23 02:38:29 [DBG] cmd.Env: []
2021/11/23 02:38:31 [DBG] Warning: Partition(s) 1 on /dev/sda have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2021/11/23 02:38:31 [DBG] /dev/sda: msdos partitions 2
2021/11/23 02:38:31 [DBG] /dev/nvme0n1: gpt partitions 1 2
2021/11/23 02:38:31 [DBG] udevadm settle --timeout 10
2021/11/23 02:38:31 [DBG] sync user is sudo_user=#1000
2021/11/23 02:38:31 [DBG] Gnome Proxy Mode: none
2021/11/23 02:38:31 [DBG] [Previous line repeated 4 times]
2021/11/23 02:38:31 [DBG] cmd.Env: []
2021/11/23 02:38:31 [DBG] lsblk --exclude 1,2,11 -J -b -O
2021/11/23 02:38:31 [DBG] parted --machine --script -- /dev/loop0 unit B print free
2021/11/23 02:38:31 [WRN] getPartitionTable() had an error reading partition table "Error: /dev/loop0: unrecognised disk label\nBYT;\n/dev/loop0:2894643200B:loopback:512:512:unknown:Loopback device:;\n"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is ""
2021/11/23 02:38:31 [DBG] parted --machine --script -- /dev/sda unit B print free
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "BYT"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "/dev/sda:32447135744B:scsi:512:512:msdos:SRT USB:"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "1:1024B:69631B:68608B:free"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "2:69632B:104927231B:104857600B:fat16::esp"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "1:104927232B:32447135743B:32342208512B:free"
2021/11/23 02:38:31 [DBG] parted --machine --script -- /dev/nvme0n1 unit B print free
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "/dev/nvme0n1:512110190592B:nvme:512:512:gpt:INTEL SSDPEKNW512G8H:"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "1:17408B:1048575B:1031168B:free"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "1:1048576B:1073741823B:1072693248B:fat32:CLR_BOOT:boot, esp"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "2:1073741824B:512109838335B:511036096512B:ext4:CLR_ROOT:"
2021/11/23 02:38:31 [DBG] setPartitionTable() line is "1:512109838336B:512110173695B:335360B:free"
2021/11/23 02:38:31 [INF] Mounting: /
2021/11/23 02:38:31 [INF] Running post-image hooks
2021/11/23 02:38:31 [INF] Installation Steps Complete
2021/11/23 02:38:31 [DBG] timeout --kill-after=30s 30s curl --no-sessionid -o /tmp/clr-installer-yaml-118332492 -s -f https://cdn.download.clearlinux.org/releases/35000/clear/config/image/.data/post-gui-install-msg.yaml
2021/11/23 02:38:39 [DBG] Post-Installation has no message content
2021/11/23 02:38:39 [DBG] Pre-Installation has no message content
