**Describe the bug**
Wanted to install on a laptop but the installer (GUI) didn…'t detected the drive. The drive is a SATA SSD disk, but I've also tested with the previous mechanical drive and the issue persisted.
Then tried using a YAML file (clr install config) to define the drive on `/dev/sda` and for a moment worked and it created the partitions but then stopped with an error. (you can read the logs for more details about the error)
I've tried with multiple CLR Linux isos (previous versions) and the same happened
The install media is fine, I use Ventoy and I have a bunch of isos in it I use regularly
Thanks
**To Reproduce**
Steps to reproduce the behavior:
1. Connect the install media/USB Stick
2. Boot into CLR
3. Open the installer
4. Enter the storage/partition options and see the error there saying it can not detect any drive
**Expected behavior**
I expect that the installer detects the drive on `/dev/sda` and then let me install the OS
**Environment (please complete the following information):**
- Clear Linux ISO file: clear-36400-live-desktop.iso
- Clear Linux OS Version: build 36400
- Installer Version 2.7.3
- Platform:
- Dell Inspiron 5458
- 8GB RAM
- Intel Core i5 5200U
- SSD Crucial MX500 - 500GB
#### sudo lshw -sanitize
computer
description: Laptop
product: Inspiron 5458 (06AE)
vendor: Dell Inc.
serial: [REMOVED]
width: 4294967295 bits
capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
configuration: boot=normal chassis=laptop sku=06AE uuid=[REMOVED]
*-core
description: Motherboard
product: 00D1NF
vendor: Dell Inc.
physical id: 0
version: A00
serial: [REMOVED]
*-firmware
description: BIOS
vendor: Dell Inc.
physical id: 0
version: A18
date: 12/30/2019
capacity: 8128KiB
capabilities: pci pnp upgrade shadowing cdboot bootselect edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification netboot uefi
*-cpu
description: CPU
product: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
vendor: Intel Corp.
physical id: 46
bus info: cpu@0
version: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
serial: [REMOVED]
slot: SOCKET 0
capacity: 2700MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap intel_pt xsaveopt dtherm ida arat pln pts md_clear flush_l1d cpufreq
configuration: cores=2 enabledcores=2 threads=4
*-cache:0
description: L1 cache
physical id: 37
slot: L1 Cache
capacity: 32KiB
capabilities: synchronous internal write-back instruction
configuration: level=1
*-cache:1
description: L2 cache
physical id: 3c
slot: L2 Cache
capacity: 256KiB
capabilities: synchronous internal write-back unified
configuration: level=2
*-cache:2
description: L3 cache
physical id: 41
slot: L3 Cache
capacity: 3MiB
configuration: level=3
*-cache
physical id: 32
slot: L1 Cache
capacity: 32KiB
capabilities: synchronous internal write-back data
*-memory
description: System Memory
physical id: 50
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
product: 99P5469-026.A00LF
vendor: Kingston
physical id: 0
serial: [REMOVED]
slot: DIMM A
width: 64 bits
clock: 1600MHz (0.6ns)
*-bank:1
product: HMT451S6BFR8A-PB
vendor: Hynix/Hyundai
physical id: 1
serial: [REMOVED]
slot: DIMM B
width: 64 bits
*-pci
description: Host bridge
product: Broadwell-U Host Bridge -OPI
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 09
width: 32 bits
clock: 33MHz
configuration: driver=bdw_uncore
resources: irq:0
*-display
description: VGA compatible controller
product: HD Graphics 5500
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:47 memory:f6000000-f6ffffff memory:e0000000-efffffff ioport:f000(size=64) memory:c0000-dffff
*-multimedia:0
description: Audio device
product: Broadwell-U Audio Controller
physical id: 3
bus info: pci@0000:00:03.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:51 memory:f7214000-f7217fff
*-usb:0
description: USB controller
product: Wildcat Point-LP USB xHCI Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:48 memory:f7200000-f720ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.17.9-1145.native xhci-hcd
physical id: 0
bus info: usb@2
logical name: usb2
version: 5.17
capabilities: usb-2.00
configuration: driver=hub slots=11 speed=480Mbit/s
*-usb:0
description: Mass storage device
product: DataTraveler 3.0
vendor: Kingston
physical id: 3
bus info: usb@2:3
logical name: scsi4
version: 0.01
serial: [REMOVED]
capabilities: usb-2.10 scsi emulated
configuration: driver=usb-storage maxpower=300mA speed=480Mbit/s
*-disk
description: SCSI Disk
vendor: Kingston
physical id: 0.0.0
bus info: scsi@4:0.0.0
logical name: /dev/sdb
serial: [REMOVED]
capabilities: removable
configuration: ansiversion=6 logicalsectorsize=512 sectorsize=512
*-medium
physical id: 0
capabilities: partitioned partitioned:dos
configuration: signature=137ffa09
*-volume:0
description: HPFS/NTFS partition
physical id: 1
logical name: /dev/sdb1
capacity: 57GiB
capabilities: primary bootable
*-volume:1
description: Windows FAT volume
vendor: mkfs.fat
physical id: 2
logical name: /dev/sdb2
version: FAT16
serial: [REMOVED]
capacity: 32MiB
capabilities: primary boot fat initialized
configuration: FATs=2 filesystem=fat label=VTOYEFI
*-usb:1
description: Video
product: Integrated_Webcam_HD
vendor: CNFEH43I22501789CB42
physical id: 5
bus info: usb@2:5
version: 42.67
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-usb:2
description: Bluetooth wireless interface
product: Bluetooth wireless interface
vendor: Intel Corp.
physical id: 6
bus info: usb@2:6
version: 0.01
capabilities: bluetooth usb-2.00
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usb:3
description: Generic USB device
product: USB2.0-CRW
vendor: Generic
physical id: 8
bus info: usb@2:8
version: 39.60
serial: [REMOVED]
configuration: driver=rtsx_usb maxpower=500mA speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@3
logical name: usb3
version: 5.17
capabilities: usb-3.00
configuration: driver=hub slots=4 speed=5000Mbit/s
*-communication
description: Communication controller
product: Wildcat Point-LP MEI Controller #1
physical id: 16
bus info: pci@0000:00:16.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: irq:49 memory:f721c000-f721c01f
*-multimedia:1
product: Wildcat Point-LP High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 03
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=32
resources: irq:52 memory:f7210000-f7213fff
*-pci:0
description: PCI bridge
product: Wildcat Point-LP PCI Express Root Port #1
physical id: 1c
bus info: pci@0000:00:1c.0
version: e3
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:42 ioport:2000(size=4096) memory:df800000-df9fffff ioport:dfa00000(size=2097152)
*-pci:1
product: Wildcat Point-LP PCI Express Root Port #3
physical id: 1c.2
bus info: pci@0000:00:1c.2
version: e3
width: 32 bits
clock: 33MHz
resources: irq:43 memory:f7100000-f71fffff
*-network
description: Wireless interface
product: Wireless 3160
physical id: 0
bus info: pci@0000:06:00.0
logical name: wlp6s0
version: 83
serial: [REMOVED]
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.17.9-1145.native firmware=17.3216344376.0 3160-17.ucode ip=[REMOVED] latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:53 memory:f7100000-f7101fff
*-pci:2
product: Wildcat Point-LP PCI Express Root Port #4
physical id: 1c.3
bus info: pci@0000:00:1c.3
version: e3
width: 32 bits
clock: 33MHz
resources: irq:44 ioport:e000(size=4096) memory:f7000000-f70fffff ioport:f0000000(size=1048576)
*-network
description: Ethernet interface
product: RTL810xE PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:07:00.0
logical name: enp7s0
version: 07
serial: [REMOVED]
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.17.9-1145.native firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=twisted pair
resources: irq:19 ioport:e000(size=256) memory:f7000000-f7000fff memory:f0000000-f0003fff
*-pci:3
product: Wildcat Point-LP PCI Express Root Port #5
physical id: 1c.4
bus info: pci@0000:00:1c.4
version: e3
width: 32 bits
clock: 33MHz
resources: irq:45
*-usb:1
product: Wildcat Point-LP USB EHCI Controller
physical id: 1d
bus info: pci@0000:00:1d.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci cap_list
configuration: driver=ehci-pci latency=0
resources: irq:21 memory:f721a000-f721a3ff
*-usbhost
product: EHCI Host Controller
vendor: Linux 5.17.9-1145.native ehci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 5.17
configuration: driver=hub slots=2 speed=480Mbit/s
*-usb
description: USB hub
product: Integrated Hub
vendor: Intel Corp.
physical id: 1
bus info: usb@1:1
version: 0.03
configuration: driver=hub slots=8 speed=480Mbit/s
*-isa
description: ISA bridge
product: Wildcat Point-LP LPC Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
*-storage
description: SATA controller
product: Wildcat Point-LP SATA Controller [AHCI Mode]
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 03
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:46 ioport:f0b0(size=8) ioport:f0a0(size=4) ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:f7219000-f72197ff
*-serial
description: SMBus
product: Wildcat Point-LP SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 03
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: irq:18 memory:f7218000-f72180ff ioport:f040(size=32)
*-scsi:0
physical id: 1
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: CT500MX500SSD1
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 043
serial: [REMOVED]
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=f726bfb6-57b0-47b0-a417-7ef8e4c27f44 logicalsectorsize=512 sectorsize=4096
*-volume:0
vendor: mkfs.fat
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
version: FAT32
serial: [REMOVED]
capacity: 511MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat name=EFI System Partition
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
version: 1.0
serial: [REMOVED]
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2022-05-24 09:46:39 filesystem=ext4 lastmountpoint=/ modified=2022-05-24 11:00:22 mounted=2022-05-24 11:00:24 state=clean
*-scsi:1
physical id: 2
logical name: scsi1
*-cdrom
description: DVD-RAM writer
product: DVD+-RW SU-208GB
vendor: TSSTcorp
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/sr0
version: D100
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-battery
product: DELL VN3N047
vendor: SMP
physical id: 1
version: 05/27/2015
serial: [REMOVED]
slot: Sys. Battery Bay
capacity: 41440mWh
configuration: voltage=14.8V
**Logs**
##### clr-installer.log
2022/05/24 06:41:30 [DBG] Log Level set to LogLevelDebug (4)
2022/05/24 06:41:30 [INF] clr-installer: 2.7.3, built on 2022-03-03_23:52:17_UTC
2022/05/24 06:41:30 [DBG] Loading config file: live-desktop.yaml
2022/05/24 06:41:30 [INF] Querying Clear Linux version
2022/05/24 06:41:30 [DBG] PrivateIP: Found IP: 52.89.132.254, Private IP?: false
2022/05/24 06:41:30 [DBG] PrivateIP: Found IP: 52.24.64.66, Private IP?: false
2022/05/24 06:41:30 [DBG] localectl list-keymaps --no-pager
2022/05/24 06:41:30 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:30 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:30 [DBG] cmd.Env: []
2022/05/24 06:41:30 [DBG] timedatectl list-timezones
2022/05/24 06:41:31 [DBG] locale -a
2022/05/24 06:41:31 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:31 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:31 [DBG] cmd.Env: []
2022/05/24 06:41:31 [DBG] Unable to use language locale 'agr_PE.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'ayc_PE.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'ber_DZ.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'ber_MA.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'bhb_IN.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'hne_IN.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'miq_NI.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'mjw_IN.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'mnw_MM.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'nhn_MX.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'shs_CA.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'the_NP.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'unm_US.UTF-8'
2022/05/24 06:41:31 [DBG] Unable to use language locale 'yuw_PG.UTF-8'
2022/05/24 06:41:31 [DBG] Mass installer using defined media in YAML
2022/05/24 06:41:31 [WRN] validatePartitions: Skipping /boot size check due to skipSize
2022/05/24 06:41:31 [WRN] validatePartitions: Skipping swap size check due to skipSize
2022/05/24 06:41:31 [WRN] validatePartitions: Skipping / (root) size check due to zero size
2022/05/24 06:41:31 [DBG] Starting install
2022/05/24 06:41:31 [INF] Running pre-install hooks
2022/05/24 06:41:31 [DBG] Clear Linux OS version: latest
2022/05/24 06:41:31 [WRN] Flag --iso not valid for physical media; disabling
2022/05/24 06:41:31 [DBG] lsblk --exclude 1,2,11 -J -b -O /dev/sda
2022/05/24 06:41:31 [INF] Cleaning disk(action): /dev/sda with ForceDestructive: false
2022/05/24 06:41:31 [DBG] removePart: Found parent: /dev/sda for child: /dev/sda1
2022/05/24 06:41:31 [WRN] Deleting part: sda1 from disk: sda
2022/05/24 06:41:31 [DBG] parted /dev/sda --script -- rm 1
2022/05/24 06:41:31 [INF] Writing partition table to: sda
2022/05/24 06:41:31 [DBG] parted -s /dev/sda mklabel gpt
2022/05/24 06:41:31 [INF] Updating partition table for: sda
2022/05/24 06:41:31 [DBG] Partitions before sorting:
2022/05/24 06:41:31 [DBG] sda1: fsType=vfat, mount=/boot, size=157286400, type=part
2022/05/24 06:41:31 [DBG] sda2: fsType=swap, mount=, size=33554432, type=part
2022/05/24 06:41:31 [DBG] sda3: fsType=ext4, mount=/, size=0, type=part
2022/05/24 06:41:31 [DBG] Partitions after sorting:
2022/05/24 06:41:31 [DBG] parted --machine --script -- /dev/sda unit B print
2022/05/24 06:41:31 [DBG] WritePartitionTable: processing child: &{sda1 vfat /boot 157286400 part false false [] false true true false false 1 []}
2022/05/24 06:41:31 [DBG] WritePartitionTable: WholeDisk mode
2022/05/24 06:41:31 [DBG] WritePartitionTable: start: 0, end: 157286400
2022/05/24 06:41:31 [DBG] WritePartitionTable: mkPartCmd: mkpart EFI fat32 0% 157M
2022/05/24 06:41:31 [DBG] parted -a optimal /dev/sda unit MB --script -- mkpart EFI fat32 0% 157M
2022/05/24 06:41:31 [DBG] WritePartitionTable: processing child: &{sda2 swap 33554432 part false false [] false true true false false 2 []}
2022/05/24 06:41:31 [DBG] WritePartitionTable: start: 157286400, end: 190840832
2022/05/24 06:41:31 [DBG] WritePartitionTable: mkPartCmd: mkpart linux-swap 157M 190M
2022/05/24 06:41:31 [DBG] parted -a optimal /dev/sda unit MB --script -- mkpart linux-swap 157M 190M
2022/05/24 06:41:31 [DBG] WritePartitionTable: processing child: &{sda3 ext4 / 0 part false false [] false true true false false 3 []}
2022/05/24 06:41:31 [DBG] WritePartitionTable: start: 190840832, end: 190840832
2022/05/24 06:41:31 [DBG] WritePartitionTable: mkPartCmd: mkpart / 190M -1
2022/05/24 06:41:31 [DBG] parted -a optimal /dev/sda unit MB --script -- mkpart / 190M -1
2022/05/24 06:41:32 [INF] Setting GUIDs for device: /dev/sda
2022/05/24 06:41:32 [DBG] sgdisk /dev/sda --typecode=3:4F68BCE3-E8CD-4DB1-96E7-FBCAF984B709
2022/05/24 06:41:32 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:32 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:32 [DBG] cmd.Env: []
2022/05/24 06:41:33 [DBG] The operation has completed successfully.
2022/05/24 06:41:33 [DBG] sgdisk /dev/sda --typecode=1:C12A7328-F81F-11D2-BA4B-00A0C93EC93B
2022/05/24 06:41:33 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:33 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:33 [DBG] cmd.Env: []
2022/05/24 06:41:34 [DBG] The operation has completed successfully.
2022/05/24 06:41:34 [DBG] sgdisk /dev/sda --typecode=2:0657FD6D-A4AB-43C4-84E5-0933C84B4F4F
2022/05/24 06:41:34 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:34 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:34 [DBG] cmd.Env: []
2022/05/24 06:41:35 [DBG] The operation has completed successfully.
2022/05/24 06:41:35 [INF] Setting boot partition: sda1 [boot]
2022/05/24 06:41:35 [DBG] parted /dev/sda set 1 boot on
2022/05/24 06:41:35 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:35 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:35 [DBG] cmd.Env: []
2022/05/24 06:41:35 [DBG] Information: You may need to update /etc/fstab.
2022/05/24 06:41:35 [DBG] partprobe /dev/sda
2022/05/24 06:41:39 [INF] Writing vfat file system to sda1 '/boot'
2022/05/24 06:41:39 [DBG] mkfs.vfat -F32 /dev/sda1
2022/05/24 06:41:39 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:39 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:39 [DBG] cmd.Env: []
2022/05/24 06:41:39 [DBG] mkfs.fat 4.2 (2021-01-31)
2022/05/24 06:41:39 [DBG] blkid --probe /dev/sda1 --output export
2022/05/24 06:41:39 [DBG] updatePartitionInfo: Updated /dev/sda1 UUID: E239-7901
2022/05/24 06:41:39 [DBG] updatePartitionInfo: Ignoring unknown line:
2022/05/24 06:41:39 [INF] Writing swap file system to sda2
2022/05/24 06:41:39 [DBG] mkswap /dev/sda2
2022/05/24 06:41:39 [DBG] Setting up swapspace version 1, size = 31 MiB (32501760 bytes)
2022/05/24 06:41:39 [DBG] no label, UUID=fb4b36f0-e07b-42e1-b9a7-03825e0a9d36
2022/05/24 06:41:39 [DBG] blkid --probe /dev/sda2 --output export
2022/05/24 06:41:39 [DBG] updatePartitionInfo: Updated /dev/sda2 UUID: fb4b36f0-e07b-42e1-b9a7-03825e0a9d36
2022/05/24 06:41:39 [INF] Writing ext4 file system to sda3 '/'
2022/05/24 06:41:39 [DBG] mkfs.ext4 -v -F -b 4096 /dev/sda3
2022/05/24 06:41:39 [DBG] mke2fs 1.46.5 (30-Dec-2021)
2022/05/24 06:41:39 [DBG] fs_types for mke2fs.conf resolution: 'ext4'
2022/05/24 06:41:39 [DBG] Discarding device blocks: 0/122050048
2022/05/24 06:41:40 [DBG] 16252928/122050048
2022/05/24 06:41:40 [DBG] done
2022/05/24 06:41:40 [DBG] Filesystem label=
2022/05/24 06:41:40 [DBG] OS type: Linux
2022/05/24 06:41:40 [DBG] Block size=4096 (log=2)
2022/05/24 06:41:40 [DBG] Fragment size=4096 (log=2)
2022/05/24 06:41:40 [DBG] Stride=0 blocks, Stripe width=256 blocks
2022/05/24 06:41:40 [DBG] 30515200 inodes, 122050048 blocks
2022/05/24 06:41:40 [DBG] 6102502 blocks (5.00%) reserved for the super user
2022/05/24 06:41:40 [DBG] First data block=0
2022/05/24 06:41:40 [DBG] Maximum filesystem blocks=2271215616
2022/05/24 06:41:40 [DBG] 3725 block groups
2022/05/24 06:41:40 [DBG] 32768 blocks per group, 32768 fragments per group
2022/05/24 06:41:40 [DBG] 8192 inodes per group
2022/05/24 06:41:40 [DBG] Filesystem UUID: c8dc7124-adf3-4ec7-ac76-5e7ad9d22228
2022/05/24 06:41:40 [DBG] Superblock backups stored on blocks:
2022/05/24 06:41:40 [DBG] 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
2022/05/24 06:41:40 [DBG] 4096000, 7962624, 11239424, 20480000, 23887872
2022/05/24 06:41:40 [DBG] , 71663616, 78675968
2022/05/24 06:41:40 [DBG] 102400000
2022/05/24 06:41:40 [DBG] Allocating group tables: 0/3725
2022/05/24 06:41:40 [DBG] Writing inode tables: 0/3725
2022/05/24 06:41:40 [DBG] Creating journal (262144 blocks):
2022/05/24 06:41:42 [DBG] done
2022/05/24 06:41:42 [DBG] Writing superblocks and filesystem accounting information:
2022/05/24 06:41:42 [DBG] 0/3725
2022/05/24 06:41:42 [DBG] blkid --probe /dev/sda3 --output export
2022/05/24 06:41:42 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:42 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:42 [DBG] cmd.Env: []
2022/05/24 06:41:42 [DBG] updatePartitionInfo: Updated /dev/sda3 UUID: c8dc7124-adf3-4ec7-ac76-5e7ad9d22228
2022/05/24 06:41:42 [DBG] updatePartitionInfo: Ignoring unknown line:
2022/05/24 06:41:42 [DBG] partprobe -s
2022/05/24 06:41:42 [DBG] /dev/sda: gpt partitions 1 2 3
2022/05/24 06:41:42 [DBG] /dev/sdb: msdos partitions 1 2
2022/05/24 06:41:42 [DBG] udevadm settle --timeout 10
2022/05/24 06:41:43 [DBG] lsblk --exclude 1,2,11 -J -b -O
2022/05/24 06:41:43 [DBG] Using default shellProxy.DefaultGetProxyValue
2022/05/24 06:41:43 [DBG] [Previous line repeated 4 times]
2022/05/24 06:41:43 [DBG] cmd.Env: []
2022/05/24 06:41:43 [INF] Running post-image hooks
2022/05/24 06:41:43 [INF] Installation Steps Complete
2022/05/24 06:41:43 [WRN] Telemetry is not present in the installer, skip record generation
2022/05/24 06:41:43 [ERR] Invalid "children" token: Invalid "children" token: Unknown block device type: dm
Error Trace:
storage.parseBlockDeviceType()
/builddir/build/BUILD/clr-installer-2.7.3/storage/block_devices.go:336
storage.(*BlockDevice).UnmarshalJSON()
/builddir/build/BUILD/clr-installer-2.7.3/storage/parse.go:134
Error Trace:
/builddir/build/BUILD/clr-installer-2.7.3/storage/parse.go:185
encoding/json.(*decodeState).object()
/usr/lib/golang/src/encoding/json/decode.go:609
Error Trace:
Error Trace:
errors.Wrap()
/builddir/build/BUILD/clr-installer-2.7.3/errors/errors.go:85
storage.parseBlockDevicesDescriptor()
/builddir/build/BUILD/clr-installer-2.7.3/storage/block_devices.go:694
##### clr-installer_terminal.log
clr-installer --config live-desktop.yaml
Swupd auto-update set to off!
Running pre-install hooks [success]
Cleaning disk /dev/sda [success]
Writing partition table to: sda [success]
Updating partition table for: sda [success]
Setting boot partition: sda1 [boot] [success]
Rescanning media [success]
Writing vfat file system to sda1 '/boot' [success]
Writing swap file system to sda2 [success]
Writing ext4 file system to sda3 '/' [success]
Running post-image hooks [success]
Installation Steps Complete [success]
ERROR: Installation has failed!
Please report this crash using GitHub Issues:
https://github.com/clearlinux/clr-installer/issues
Include the following as attachments to enable diagnosis:
/root/pre-install-clr-installer.yaml
/root/clr-installer.log
You may need to remove any personal data of concern from the attachments.
The Installer will now exit.
Error Trace:
Error Trace:
Error Trace:
Error Trace:
errors.Wrap()
