Disk encryption passphrase - nothing happens
New install of Clear OS. FOUR TIMES.
Disk encryption set up, no “funny characters”, just letters and numbers. On restart the passphrase entry does absolutely nothing. It just sits there blinking at me.
I really would like to use Clear OS but this is currently a big no no.
Can anyone suggest why the passphrase entry does absolutely nothing?
I believe this is related to Not start new kernel - #10 by btwarden
Thanks. Will the solution be added to a future release?
New to clear linux (fedora user), I’m having this same problem after a system update (org.clearlinux.native.6.12.1-1493). how do I switch to the older kernel during bootup.
was able to boot into my system, had to chroot into my rootfs from the live media. changed the boot manager timeout, switched to older kernel (org.clearlinux.native.6.10.6-1459), keyboard input worked.
