Kernel 6.12.1 on 42710 issue at boot
This issue already happen in the past.
On a fully encrypted disk, the new kernel 6.12.1, don’t read the keyboard entries (the password, to decrypt and continue booting).
This was already resolved by @btwarden on June 25th : Not start new kernel - #8 by angusyoung1794 :
“I believe I’ve tracked down the problem to kernel module compression – specifically, during initrd, the kernel isn’t able to decompress modules because it was expecting to use external utilities. I’m reworking the initrd to have the keyboard driver modules already decompressed.”
Please, consider this fix for the next release.
Thanks for your efforts!
Interesting. I was wondering why OS would completely stop on login.
I thought it was because I use a USB keyboard and mouse.
I also, thought it may be the windows 10 boot HD in the computer until I removed it and it still occurred.
In the old DOS days, I would make sure the drivers needed for login would load in high mem block during boot up. Dose Linux also do this?
we made a change to move the keyboard drivers into the kernel (rather than as modules) – sounds like this does not work for you
are there any error messages that indicate what is going wrong maybe?
Hi @arjan, no, no error at all. I just select the kernel at boot, and when asks for the passphrase to decrypt the disk, I just type it in the keyboard, and no echo of ‘******’ is showed on the screen. I type it completely, and, when I press enter, there’s no action.
Can you tell us what keyboard you have (lsusb)? Can you try adding debug to the kernel command line (man clr-boot-manager for details) to see if there’s anything useful?
I don’t have an external keyboard:
root@dell~ # lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0c45:6717 Microdia Integrated_Webcam_HD
Bus 001 Device 003: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 011: ID 046d:c077 Logitech, Inc. Mouse
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
root@dell~ #
I have a Dell Latitude 7490:
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Dell Inc.
Product Name: Latitude 7490
Version: Not Specified
Serial Number: *******
UUID: ----
Wake-up Type: Power Switch
SKU Number: 081C
Family: Latitude
I just select the kernel to boot:
And the next image that I get is the password requirement:
I will try to add some debug as soon as I can.
Thanks for fix this issue with the new kernel ‘6.12.1-1499.native’.
I have recently updated to 42760, and now the keyboard works, and I can boot on a full encrypted disk.
Thanks for your help!
