I’m seeing docker issues again:
$sudo swupd update
Update started
Version on server (42680) is not newer than system version (42680)
Update complete - System already up-to-date at version 42680
$ uname -a
Linux books.box 6.11.6-1477.native #1 SMP Thu Oct 31 18:41:56 PDT 2024 x86_64 GNU/Linux
$ docker image ls quay.io/vektorlab/ctop
REPOSITORY TAG IMAGE ID CREATED SIZE
quay.io/vektorlab/ctop latest ed869812e1a4 2 years ago 13.2MB
$ cat ctop
#!/usr/bin/env bash
docker stop ctop
docker run --rm -ti \
--name=ctop \
--volume /var/run/docker.sock:/var/run/docker.sock:ro \
quay.io/vektorlab/ctop:latest
$ ./ctop
Error response from daemon: No such container: ctop
docker: Error response from daemon: failed to create task for container: failed to start shim: start failed: unsupported shim version (3): not implemented.
ERRO[0000] error waiting for container:
Using a rollback script to 41840 makes things work again:
cat rollback-docker.sh
#!/usr/bin/env bash
# a script to rollback docker to a currently working version
VERSION=41840
sudo swupd repair --verbose --version $VERSION --bundles=containers-basic --force
sudo swupd autoupdate --disable
cat /etc/os-release
