Hello,
I found my webserver down this morning and noticed that the computer running CL did a reboot.
Does CL reboots itself after an major update ? I’m not sure if there was a power cut responsible for that or if CL did restarted itself …
Hello,
No, Clear Linux doesn’t reboot intentionally. You may see messages regarding the need to reboot when logging in after an update, but it prompts you to reboot manually.
Rgds,
Chris
if there was a reboot, you should be able to find out from journalctl info. Also, uptime and last commands may prove useful in determining when a reboot occurred.
Some services may be automatically restarted by clr-service-restart. Read its man page how you can control which services are allowed to automatically restart.
