Hello. Is there a way to avoid specific packages from being downloaded when installing a bundle? For instance, the Games bundle contains supertuxkart and minetest, which I clearly do not need.
If that’s not possible, what about a way to individually delete said packages?
Thank you. I was hoping there would be a way to install specific packages (I wanted to use vulkaninfo and I had to download a whole 2GB bundle for it - found a GUI for it only afterwards), but the method you described will do too.
