swupd
does not remove deps on removing bundles, and there is no options for bundle-remove
to do that, but it seems that swupd
does not have a autoremove
either.
Besides, does swupd
mark bundles as manually installed
or deps
swupd
either.
Besides, does swupd
or deps
Hi @yw662!
According to the swupd documentation:
Bundles provide a particular functionality, or stack, which include all associated runtime dependencies.
Therefore, as far as I understand, running swupd bundle-remove
should also remove the runtime dependencies contained in that particular bundle. However, I would expect the opinion of someone more experienced than me on this.
Weren’t they removed on your system?
swupd bundle-remove
remove exactly 1 bundle.
Exp, if you run swupd bundle-add akonadi
, it will also install libstdcpp, libgstd, lib-opengl, find-utils, p11-kit, python3-basic, font-basic, lib-openssl, libX11client, qt-core, qt-basic, lib-qt5webengine, and kde-framework5, if they are not installed.
After that, if you run swupd bundle-remove akonadi
, it will exactly remove and only remove akonadi, even if, exp, kde-framework5 is no longer required by any other bundles.
That is when apt/yum autoremove
should be useful. It will remove all packages(bundles) that is not required by any “manually installed” packages(bundles).
Information on installed bundles are under /usr/share/clear/bundles/
. Available bundles, installed and not installed, are available in the manifest file at /var/tmp/swupd/Manifest.MoM
. To see this,
sed '/^[^M]/d' "/var/tmp/swupd/Manifest.MoM" | cut -f4
swupd
does store information on dependencies in spec
files, you can check this with
cat /usr/share/clr-bundles/BUNDLE
Take desktop-autostart
bundle as an example, it directly includes two packages gdm-autostart
and gnome-initial-setup
, but also relies on desktop
bundle.
# [TITLE]: desktop-autostart
# [DESCRIPTION]: Bundle to automatically launch the GUI upon boot.
# [STATUS]: Active
# [CAPABILITIES]:
# [TAGS]: Other
# [MAINTAINER]: Marcos Simental <marcos.simental.magana@intel.com>
include(desktop)
gdm-autostart
gnome-initial-setup
This can also be found in /usr/share/clear/allbundles/desktop-autostart
, where it says
"DirectIncludes": [
"desktop"
"DirectPackages": {
"gdm-autostart": true,
"gnome-initial-setup": true
This has nothing to do with autoremove
feature. You would always have to manually remove desktop
after remove desktop-autostart
I was answering the question.
Actually you are not. By “mark”, it means, the package management system knows whether a particular package is “manually installed by the user” or “automatically installed by the package manager”. That spec file can do nothing about the mark.
Anything not in the spec files are not installed by swupd.
So that does mean,
swupd
do not know which bundles are “explicitly installed”,swupd
cannot provide a bundle list in which “bundles are neither explicitly installed, nor required by any explicitly installed package”,autoremove
is impossible for swupd
.is it right ?
Suppose you invoke swupd to add bundle A, which includes bundle B.
This is inconvenient but the reasoning is this, bundles are not packages but functionalities, which is a higher level abstraction of underlying packages.
For this reason, though we call bundle B as A’s dependency, it’s be more proper to think A as B’s superset in terms of the functionality.
Normally for other distros, if you removed a package then naturally it’s dependencies are not likely to be needed. But from a functionality point of view, removing one functionality doesn’s mean you want to remove it’s superset. For example, say you don’t want a refrigerator that also makes carbonated water, but it doesn’t necessarily mean you don’t want a fridge.
So there’s no equivalent thing as autoremove, because whether to remove another functionality, i.e bundle, should be determined by users.
Currently, yes, this is the state. However, we intend to soon introduce features that would make this possible (most of the code is already in place, we just need to finish the last changes that would make this doable and rewrite many of the bundles).
What’s the state of this functionality? Can you give some hints?
