How to connect to WebDav Sharefolder?
hello…
how to mount (fstab) WebDav?
I didnt found any way to connect to a WebDav Sharefolder?
You can connect using the GNOME file browser (nautilus) using the instructions here: Browse files on a server or network share
Yes, i know… this works perfect…
but i need another way to connect to my NAS.
No way to use mount?
There is davfss but it is not packaged by Clear Linux.
You can always compile it and its dependencies to install locally using the standard ./configure && make && make install
