How do I get plasma-systemmonitor installed?
I set up KDE the following way:
installed clear-42170-live-server.iso
Sudo swupd bundle-add desktop-kde
Sudo swupd bundle-add desktop-kde-apps
i@clr~ $ sudo dnf repoquery -l plasma-systemmonitor-bin --repo=clearlinux
Unable to detect release version (use '--releasever' to specify release version)
Failed loading plugin "system_upgrade": No module named 'systemd'
Last metadata expiration check: 0:01:15 ago on Sun 18 Aug 2024 06:32:31 AM +08.
/V3/usr/bin/plasma-systemmonitor
i@clr~ $ sudo swupd search-file /usr/bin/plasma-systemmonitor
[100%]
Searching for '/usr/bin/plasma-systemmonitor'
Search term not found
Not in any bundle, will have to request in the github
