trying to install on acer laptop. error happens during “writing swap file system to sda2”. using entire ssd of laptop. ???
Update - Evidently the installer will not erase the target disk. Had to remove partitions, then install has progressed to “installing base OS …” So far, so good.
Glad to hear you got it figured out!
