Hi there!
I’m David and I’m new in this community and with this distro, I tried to install it, but unfortunately I can’t.
I found a curious thing while doing the installation process. When the partitions on the HDD were made the partition root had only 150MB and the boot partition had 60GB as well.
I forget to mention that the installation I was being done directly on my HDD with one partition that has 60GB.
I really appreciate to get some help from you!!
Thanks.
I’ll attach some pictures.
Size of the partition.
