Hello, i planned to install Clear Linux to my laptop, it feels rock solid, booted very fast and no needed boot args to disable nouveau driver (i need it always on other dists.).
But when i run installer and set everything up, installer took very long time. For example i ran installer, it still running after 12 hours later.
I took a look to this topic, but my Internet is well. It can’t take time like 12 hours to download bundles. I looked up to Htop, CPU is work on a command like ‘swupd --verify’. It working before when i left the computer -before of 12 hours- and still running after 12 hours.
I’m having the same issue right now, installed once same device no issues. This time it hangs, probably just going to reboot and retry. No processes are using any resources (except firefox).
Hi all,
Can I ask which installer/version of the OS you were using to do the installation and when were you actually trying to do the install? On Sunday?
Have you retried since? Are you still seeing the issue? We did do a format bump before the weekend, and it’s possible that there may have been some hiccups as the files were proliferated to the CDN servers, but it should all be working now. If you’re still seeing issue, please file a bug at Issues · clearlinux/distribution · GitHub
Yeah, same here. I have noticed it installs much faster if I don’t select any additional bundles under the ‘advanced options’ tab. Everyone would expect that but it seems to save a disproportionate amount of time.
no I haven’t. but there’s no difference in the way how bundles are installed in the live ISO and in the actual CL system. they are always downloaded from the server, so I doubt it will take shorter to install them after OS is installed.
