hi, im have one problem when installing. the problem is, when i was installing, it came verifying step that cause longer to install. can you help?
same issue did you fix?
Currently, there are gaps in the progress bar reporting which can make a few of the installation steps appear to be frozen, even though the installation is still continuing successfully. If you wait longer, the installation should continue. Updates to the progress bar reporting have been merged in the clr-installer and swupd projects, but they still need to make a release with these changes.
