Hi;
I switched from mint to clear linux discovering mint is not as fast as windows for my intel i7. I though it was because of processor optimization stuff because I don’t think windows can be a good OS ever especially a fast one lol. However after switching to CL improvement was visible but the issues started with nvidia drivers. Idk which application it was but I was able to use CUDA on demand in linux mint.
When trying to install I was unsucessful probably because I couldn’t disable a GPU, as a result I ended up being in stuck in the black CLI without GUI. Instead of trying to solve from the cli I just did another clean install but this time I used lts kernel. my pulse audio driver stuff was misconfigured somehow then switched to native kernel again and it was solved but now I have scary red lines on my dmesg output.
An example from dmesg
traps: gnome-photos[4763] trap int3 ip:7f0c7dad918e sp:7ffec65e0650 error:0 in libglib-2.0.so.0.6600.7[7f0c7da6f000+f0000]
[ 1302.216801] crashprobe[4858]: segfault at 10 ip 00007f6cdb6cc728 sp 00007ffdeac490a0 error 4 cpu 7 in libdw-0.183.so[7f6cdb68e000+45000]
[ 1302.216808] Code: ff c0 48 39 45 18 75 e9 eb e3 31 c0 80 7d c4 02 75 18 2e 2e 49 8b 14 c0 48 0f ca 49 89 14 c4 48 ff c0 48 39 45 18 75 ea eb c3 <49> 8b 14 c0 49 89 14 c4 48 ff c0 48 39 45 18 75 ef eb b0 b0 01 48
[ 1302.216818] Process 4858(crashprobe) has RLIMIT_CORE set to 1
My Device: Dell G3 15, Nvidia 1660Ti
I use frequent Machine Learning and I want to be able to switch my GPU with Bumblebee/Primus or something.
My Question Is: Should I use clear linux*. I can learn & modify stuff and solve this issues the problem is that I don’t have the time and it feels unstable honestly. If I can contribute for my devices here on clear linux it would become more stable I think, at least the code will be reviewed. Is CL at this stage where I can install/use bumblebee from swupd in the following 3 months or so?
If thats the case I would like to make the effort.
