Hi,
I’m re-installng all my previous CLR and New ones because of the non-destructive encryption,
so Great !
Most of my computer have French(Switzerland) Keyboard
- I’m using clear-36010-live-desktop.iso Live USB,
- I select French(Switzerland) Layout on general Gnome Setting of the Live USB before install,
- I make an classical Installation with :
- Safe Installation
- Enabled Encryption
- French(Switzerland) Keyboard Layout
At reboot :
- Luks = Good Layout | Encryption password contains French(Switzerland) chars and it is OK |
- Login = Bad Layout (US default) | I use ‘?’ to obtain ‘-’ , … |
- Logged = Good Layout | everything is OK |
How Can I set the correct Layout Keyboard on Gnome? boot ? Grub ???
I tried to change the Langauge / Country … to French(Switzerland) the same PB.
Thanks for Help,
Best Regards
Something Funny
If I lock my station the Login has the good Keyboard Layout French(Switzerland) ![]()
