Logitech Wireless Devices
I’m having no luck getting my wireless mouse and keyboard ( none of which are bluetooth) to be recognized or connect to Clear’s Operating System.
Solaar tells me the devices are off line (they aren’t).
So what else can I do besides using Solaar?
They need to be paired with the receiver. That can be done on a Windows computer if there is no pairing tool for Linux. Once they are paired just move the USB receiver over to the Linux PC.
You know what I am using a different receiver. I will try that thanks.
Yes, that did it. Thanks again.
