no puedo hacer funcionar la placa de red Ethernet mi wifi adjuntos datos
lshw -c network
description: Network controller
product: Centrino Wireless-N 2230
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: c4
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:d0700000-d0701fff
description: Ethernet controller
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
version: 0c
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd cap_list
resources: ioport:e000(size=256) memory:d0604000-d0604fff memory:d0600000-d0603fff
lspci |grep et
02:00.0 Network controller: Intel Corporation Centrino Wireless-N 2230 (rev c4)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
uname -a
Linux casa2 5.13.13-1070.native #1 SMP Thu Aug 26 08:03:35 PDT 2021 x86_64 GNU/Linux
Visor de Registros
r8169 0000:03:00.0: unknown chip XID fcf, contact r8169 maintainers (see MAINTAINERS file)
iwlwifi 0000:02:00.0: HW_REV=0xFFFFFFFF, PCI issues?
cleart
May 13, 2022, 1:45pm
#2
try
sudo modprobe r8169
if that doesn’t work,
perhaps try downloading the driver from here
root@casa2~ # modprobe r8169
no arroga ningun resultado
descarge el r8168-8.050.00 de la paguina de Realtek
el querer instalarlo arroga el sig mensaje
Check old driver and unload it.
rmmod r8169
Build the module and install
make[2]: *** No hay ninguna regla para construir el objetivo ‘clean’. Alto.
make[1]: *** [Makefile:162: clean] Error 2
make: *** [Makefile:48: clean] Error 2
dmesg | grep r8169
[ 18.130071] calling rtl8169_pci_driver_init+0x0/0x1000 [r8169] @ 201
[ 18.130345] r8169 0000:03:00.0: unknown chip XID fcf, contact r8169 maintainers (see MAINTAINERS file)
[ 18.160926] initcall rtl8169_pci_driver_init+0x0/0x1000 [r8169] returned 0 after 30108 usecs
[13081.488896] calling rtl8169_pci_driver_init+0x0/0x1000 [r8169] @ 19456
[13081.489255] r8169 0000:03:00.0: unknown chip XID fcf, contact r8169 maintainers (see MAINTAINERS file)
[13081.500217] initcall rtl8169_pci_driver_init+0x0/0x1000 [r8169] returned 0 after 11034 usecs
[14690.148360] calling rtl8169_pci_driver_init+0x0/0x1000 [r8169] @ 22006
[14690.148714] r8169 0000:03:00.0: unknown chip XID fcf, contact r8169 maintainers (see MAINTAINERS file)
[14690.159609] initcall rtl8169_pci_driver_init+0x0/0x1000 [r8169] returned 0 after 10962 usecs
[17431.213784] calling rtl8169_pci_driver_init+0x0/0x1000 [r8169] @ 26127
[17431.214214] r8169 0000:03:00.0: unknown chip XID fcf, contact r8169 maintainers (see MAINTAINERS file)
[17431.225006] initcall rtl8169_pci_driver_init+0x0/0x1000 [r8169] returned 0 after 10884 usecs
cleart
May 13, 2022, 4:33pm
#5
you can download realteks driver:
(r8168)
Realtek PCIe FE / GBE / 2.5G / Gaming Ethernet Family Controller Software - REALTEK
you can do what it says, contact the mantainers:
mailto:hkallweit1@gmail.com
mailto:nic_swsd@realtek.com
(M: is the mantainer. L: is the mailing list)
cleart
May 13, 2022, 6:01pm
#6
the driver download link i gave was a temporary link.
i have updated it to go to the selection page instead.
scroll down and find the r8168 driver
