The first time I rebooted my device Ethernet worked well.
I have installed Brave browser on my laptop and then rebooted the device.
The second time it booted, Ethernet link is not up.
$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq state DOWN mode DEFAULT group default qlen 1000
link/ether ac:e2:d3:7a:5e:f7 brd ff:ff:ff:ff:ff:ff
$ ip link
Are you using WiFi connection?
Try to enable it, in the top right corner menu from Gnome.
Your wifi device is present but fails to initialize. It could be due to missing firmware. Check dmesg for any hints regarding missing firmware or other issues.
As for the ethernet failure, try using networkctl or the gui to enable it. This may be related to other ethernet networking issues we’re currently having that are being reported.
You are right. There’s no WiFi drivers installed for my laptop.
I struggle almost half a day yesterday to bring Ethernet port up. Today I came to office to resolve this and to my surprise, it’s up and got IP address (Don’t know why it didn’t yesterday) when I booted my laptop.
And I see a bug in the UI. Even though Ethernet link is established, I still see disconnected symbol from top right corner.
I always have this problem after reboot at work with wired Ethernet, and time to time on my home wifi connections. Recently Clear Linux made the large steps toward great UX and those bugs/problems questionably can be considered as the main bottleneck, IMHO.
Thanks, good to know. I need to finish my current job on my workstation (ETA - next Mon), then I will reboot and let you know. In the same time I will watch for my home laptop - last time it happened 2 days ago.
On laptop, wifi, at home - no failures. At work, wired, same behavior - initially after reboot there is no connection, turning once the button “Connect” makes connection working, but still showing indication status as “Unmanageable”. Not a big deal, it works, but a bit annoying.
