Hello. I have a multifunctional device “Epson L366”.
This device works great as example in Ubuntu and other Linux distros. But not in Clear Linux.
Manufacturer has a driver for Linux kernel. I have installed it via rpm package. As I understand an outpout if “rpm” the package was installed successfully. But when I connect my device via USB. the device not recognized via CUPS (works in other distoros with same kernel versions). In “dmesg” after connectiong a device I see a strange messages:
[ 129.927159] usb 1-1: new high-speed USB device number 8 using xhci_hcd
[ 130.062142] usb 1-1: New USB device found, idVendor=04b8, idProduct=08d2, bcdDevice= 1.00
[ 130.062144] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 130.062145] usb 1-1: Product: EPSON L366 Series
[ 130.062146] usb 1-1: Manufacturer: EPSON
[ 130.062147] usb 1-1: SerialNumber: 5648384B3031323306
[ 130.072933] usblp 1-1:1.1: usblp0: USB Bidirectional printer dev 8 if 1 alt 0 proto 2 vid 0x04B8 pid 0x08D2
[ 130.072949] probe of 1-1:1.1 returned 1 after 4564 usecs
[ 130.072963] probe of 1-1 returned 1 after 10737 usecs
Seems something wrong with drivers. But I can not find any solution or same info about same things…
Can anyone help me to solve this issue?
Sorry, the problem is solved, problem was in cups not in drivers. I need just add a printer device /dev/lp0 manually in cups administration interface and select right model and PPD file for my printer.
Hi can you tell me how did you install the RPM driver in CL?
I am trying to compile from source the drivers and I cant because missing CUPS config.
When I run ./configure I get:
checking cups/cups.h usability… no
checking cups/cups.h presence… no
checking for cups/cups.h… no
checking cups/ppd.h usability… no
checking cups/ppd.h presence… no
checking for cups/ppd.h… no
checking cups/raster.h usability… no
checking cups/raster.h presence… no
checking for cups/raster.h… no
Then, when I run make I get an error:
wrapper.c:25:10: fatal error: cups/cups.h: Does not exist file or directory
25 | #include <cups/cups.h>
If anyone can help me to install the driver via RPM or compiling I will appreciate it too much
