Hi, newcomer here but long-time GNU/Linux user (I started in 1993). So far, I like Clear Linux a lot, even though it’s still a bit rough on the edges compared to say Ubuntu or Fedora.
My question: I installed Java 8 and have an executable JAR file. I can execute from the command-line but in the GUI, Nautilus only proposes me to extract it as an archive. I would welcome some help here
Can you right-click and open with another application? That should also allow you to change the default program JAR files are opened with: Open files with other applications
Yes I know this but it unfortunately doesn’t work. When clicking “View All Applications”, I’m not proposed to use Java. I tried the action called “Run Software” but it doesn’t do anything visible. I have Java 8 installed and I also set the executable bit to true on the JAR file in question, in case there was a problem here, but to no avail. Running from the command line with java -jar
works perfectly.
The MIME type is identified as “Java archive” (application/x-java-archive), which seems good.
It looks like Nautilus loads the options based on the *.desktop
files found in /usr/share/applications
. There is not one for Java. (I’d guess most security folks will say it’s a good thing that files aren’t passed to java by default.)
You could define one locally under ~/.local/share/applications/
for java to pass the file to it.
Source:
gnome - How can I add an application to the list of Open With applications? - Ask Ubuntu
Gnome files Nautilus context menu "Open with" application list - Stack Overflow
As @puneetse said, Nautilus lists applications according to the MimeType
they have in there *.desktop
files.
In I did a `grep -iR ‘.jar’ /usr/share/mime’ and below is the output
./application/x-java-archive.xml: <glob pattern="*.jar"/>
./globs:application/x-java-archive:*.jar
./globs2:50:application/x-java-archive:*.jar
./packages/freedesktop.org.xml: <glob pattern="*.jar"/>
In /usr/share/mime/application/x-java-archive
, it says
<alias type="application/x-jar"/>
<alias type="application/java-archive"/>
Then it turns out on my system the only application that opens jar
is org.gnome.FileRoller.desktop
, which is the archive manager of gnome.
So I made a desktop file myself with the following
[Desktop Entry]
Type=Application
Version=1.0
Name=Jar Opener
# This is for opening files, not launching the notebook from a menu
NoDisplay=true
Exec=java -jar %f
Terminal=true
MimeType=application/x-java-archive;
It’s also available here.
Place it under ~/.local/share/applications
and run `update-desktop-database ~/.local/share/applications’ and you’re good to go.
P.S. I have to specify the directory when update-desktop-database
, otherwise it doesn’t work, because it’s not in $XDG_DATA_DIRS
. Maybe we should patch filesystem
package to include this directory.
It works, thank you very much.
