I use Clear Linux on Mac mini 2018 (Core i5 -8500B). I am able to boot into Clear Linux without much of a hassle. However, I am unable to shut it down. the command shutdown ends in kernel panic with a huge list of commands similar (but not same) to this: systemctl poweroff: kernel panic · Issue #186 · clearlinux/distribution · GitHub.
Today I realized, that the shutdown does not kills any process but just freezes without accepting any input from the keyboard. Is there a way I can fix this issue?
PS: I am not a linux expert! I dont know to save the shutdown command output as log file.
Thanks for the reply!
Yes! Same issue! However I accidentally figure out a safe way to restart. I use sudo halt -p --force in one terminal. It will not do anything atleast visually. I will open a new terminal and type sudo shutdown -h now.
This will throw series of command with SIGTERM and after ~10 min it’ll stop at powering off but will not turn off. Here, I’ll press ctrl+alt+del and it’ll reboot.
sudo clr-boot-manager update is not doing anything! There is no output at all similar to sleep command. I tried using this command sudo CBM_DEBUG=1 clr-boot-manager update the output is
[DEBUG] cbm (../src/cli/cli.c:L142): No such file: //etc/kernel/update_efi_vars
[INFO] cbm (../src/bootman/bootman.c:L744): Current running kernel: 5.7.6-966.native
