My NUC (I posted specs here) is shutting down mysteriously and I can’t find anything in /var/log. No kernel panics, nothing in the journals (I checked all of them!).
I’m guessing that DDR is corrupt and CL is crashing, but I can’t confirm this.
Anyone has experienced this? I’ve exhausted all the places I thought I could find useful information in.
Hmm, try a syslog or maybe follow journals journalctl -f over ssh remotely while attampting to replicate the crash?
The similar experiences I’ve had were due to nvidia driver errors, which can happen on any system.
also make sure your power supply unit and power cord are both good. a bad power connection should be ruled out first.
I tried journalctl with no luck but doing it over ssh with -f seems like a good option. Thanks!
Seems basic but you’re right. Thanks.
