Is there any way to install Rawtherapee https://rawtherapee.com/ It is RAW-converter. In my point of view, It is a powerful tool, might be it contains the setting of a lot, but a result image can be comparable with Capture One.
I know, there is Darktable, but sorry it is in big distance from Rawtherapee, and much more from Capture One.
looks at the download page
why would you want to install it?
I do not know how to handle with .AppImage files⦠(RawTherapee-releases-5.6-20190420.AppImage) Software tells: āFailed to install file: file not supportedā.
AppImage doesnāt work on Clear Linux.
It does. And the RawTerapee AppImage also works on clearlinux. However, the instructions for using them are slightly different:
- Download the appimage (save asā¦)
- Make it executable:
chmod +x $appimage
- run it:
./$appimage
I tried it and it works. Most, if not all appimages, should all just work fine on clearlinux.
Thanks! I will try that!
Version : 5.6
Prefix : RawTherapee-5.6
Buildreqs : buildreq-cmake cmake libjpeg-turbo-dev libpng-dev pkg-config
Buildreqs : pkgconfig(cairomm-1.0) pkgconfig(expat) pkgconfig(fftw3f) pkgconfig(gio-2.0) pkgconfig(giomm-2.4)
Buildreqs : pkgconfig(glib-2.0) pkgconfig(glibmm-2.4) pkgconfig(gobject-2.0) pkgconfig(gthread-2.0) pkgconfig(gtk+-3.0)
Buildreqs : pkgconfig(gtkmm-3.0) pkgconfig(lcms2) pkgconfig(lensfun) pkgconfig(libiptcdata) pkgconfig(librsvg-2.0)
Buildreqs : pkgconfig(libtiff-4) pkgconfig(sigc++-2.0) zlib-dev
Summary : No detailed summary available
License : GPL-3.0 (server) ( e356a1be060a7aaaf8a697871a9e24c9ea5dda17 )
License : GPL-3.0 (server) ( d8cd7005d36397bc46fe74851453e57418cdd5c1 )
Licenses : GPL-3.0
Iām seeing if we can just package it natively in clearlinux
Looks like it works! Iāll bundle this and itāll be available in 1-2 days as a swupd
bundle!
This is very nice software⦠the quality of conversion is one of the best out there.
Itās great having RawTherapee bundle. Would be even better with lensfun included.
I was able to build and install lensfun from source, but not run. Probably something with paths?
omen@clearlinux~ $ lensfun-update-data
File ā/usr/local/bin/lensfun-update-dataā, line 46, in
import lensfun
ModuleNotFoundError: No module named ālensfunā
