I have been attempting to use Sonicwall NetExtender. Running it from the command line gives the error:
You need to create the /dev/ppp device node by
executing the following command as root:
mknod /dev/ppp c 108 0
Running this command solves the problem until reboot. Further investigation demonstrated that the ppp_generic kernel module is not being loaded on demand by udev as it is in many distributions. I now execute the command modprobe ppp_generic on boot and it seems to work fine.
Should udev be configured to load this kernel module on demand by default?
