I have been wanting to use Clear Linux as my main OS for a while now, but I keep running into issues. Perhaps my obscure hardware may be the source… One of the major issues is that my rear USB ports do not seem to be working properly in Clear. I have an AIO with two USB ports on the side and four on the rear. When Clear starts up, I cannot use the mouse and keyboard that would normally be plugged into the rear. The mouse’s light is on, so there is power. No devices plugged into the rear USB ports seem to be recognized.
I am on Clear Desktop version 30710
Below is the output of lshw
clr-live
description: Desktop Computer
product: 23-b030 (H3Y91AAR#ABA)
vendor: Hewlett-Packard
serial: 3CW2420BHN
width: 4294967295 bits
capabilities: smbios-2.7 dmi-2.7 smp vsyscall32
configuration: boot=normal chassis=desktop family=103C_53316J G=D sku=H3Y91AAR#ABA uuid=A0E698BC-F40E-E211-93D0-4C72B9DA4A94
*-core
description: Motherboard
product: 2AEE
vendor: PEGATRON CORPORATION
physical id: 0
version: 1.03
serial: 3CR2420BHN
*-firmware
description: BIOS
vendor: AMI
physical id: 0
version: 8.10
date: 09/24/2012
capacity: 4032KiB
capabilities: pci pnp upgrade shadowing cdboot bootselect edd int5printscreen int14serial int17printer acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: 7
slot: System board or motherboard
*-bank:0
description: DIMM DDR3 Synchronous Unbuffered (Unregistered) 1600 MHz (0.6 ns)
product: NMSO380D81-1600C
vendor: Undefined
physical id: 0
serial: 0200000
slot: DIMM1
width: 64 bits
clock: 1600MHz (0.6ns)
*-bank:1
product: 16KTF51264HZ-1G6M1
vendor: Micron
physical id: 1
serial: DF9354D
slot: DIMM2
width: 64 bits
*-cache:0
description: L1 cache
physical id: 25
slot: L1 CACHE
capacity: 96KiB
clock: 1GHz (1.0ns)
capabilities: pipeline-burst internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 26
slot: L2 CACHE
capacity: 1MiB
clock: 1GHz (1.0ns)
configuration: level=2
*-cpu
description: CPU
product: AMD A4-5300 APU with Radeon(tm) HD Graphics
vendor: Advanced Micro Devices [AMD]
physical id: 2b
bus info: cpu@0
version: AMD A4-5300 APU with Radeon(tm) HD Graphics
slot: P0
capacity: 3400MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 popcnt aes xsave avx f16c lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs xop skinit wdt lwp fma4 tce nodeid_msr tbm topoext perfctr_core perfctr_nb cpb hw_pstate ssbd vmmcall bmi1 arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold cpufreq
configuration: cores=2 enabledcores=2 threads=2
*-pci:0
description: Host bridge
product: Family 15h (Models 10h-1fh) Processor Root Complex
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 66MHz
*-display
description: VGA compatible controller
product: Trinity 2 [Radeon HD 7480D]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 1
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:36 memory:c0000000-cfffffff ioport:f000(size=256) memory:feb00000-feb3ffff memory:c0000-dffff
*-pci:0
description: PCI bridge
product: Family 15h (Models 10h-1fh) Processor Root Port
physical id: 4
bus info: pci@0000:00:04.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:24 ioport:e000(size=4096) ioport:d0000000(size=1048576)
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 07
serial: 4c:72:b9:da:4a:94
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=x.x.x.x latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:16 ioport:e000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
*-pci:1
physical id: 5
bus info: pci@0000:00:05.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:25 memory:fea00000-feafffff
*-network
description: Wireless interface
product: RT5390R 802.11bgn PCIe Wireless Network Adapter
vendor: Ralink corp.
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 00
serial: 62:9b:e5:9c:e4:34
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rt2800pci driverversion=5.2.7-816.native firmware=0.40 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:fea00000-fea0ffff
*-pci:2
physical id: 7
bus info: pci@0000:00:07.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:26 memory:fe900000-fe9fffff
*-generic
description: Unassigned class
product: RTS5209 PCI Express Card Reader
physical id: 0
bus info: pci@0000:03:00.0
version: 01
width: 32 bits
clock: 33MHz
configuration: driver=rtsx_pci latency=0
resources: irq:27 memory:fe901000-fe901fff
*-usb:0
description: USB controller
product: FCH USB XHCI Controller
physical id: 10
bus info: pci@0000:00:10.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:18 memory:feb46000-feb47fff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.2.7-816.native xhci-hcd
physical id: 0
bus info: usb@3
logical name: usb3
version: 5.02
capabilities: usb-2.00
configuration: driver=hub slots=2 speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@4
logical name: usb4
version: 5.02
capabilities: usb-3.00
configuration: driver=hub slots=2 speed=5000Mbit/s
*-usb:1
physical id: 10.1
bus info: pci@0000:00:10.1
version: 03
width: 64 bits
clock: 33MHz
resources: irq:17 memory:feb44000-feb45fff
*-usbhost:0
physical id: 0
bus info: usb@5
logical name: usb5
version: 5.02
*-usb:0
description: Keyboard
product: USB Receiver
vendor: Logitech
physical id: 1
bus info: usb@5:1
version: 12.01
configuration: driver=usbhid maxpower=98mA speed=12Mbit/s
*-usb:1
description: Mass storage device
product: Ultra
vendor: SanDisk
physical id: 2
bus info: usb@5:2
logical name: scsi6
version: 1.00
serial: 01010ed1ec90424b9f768dab7ae007c5d595524191858f2a31710ec630270146b172000000000000
capabilities: usb-2.10 scsi emulated
configuration: driver=usb-storage maxpower=224mA speed=480Mbit/s
*-disk
description: SCSI Disk
product: Ultra
vendor: SanDisk
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sdb
version: 1.00
capabilities: removable
configuration: ansiversion=6 logicalsectorsize=512 sectorsize=512
*-medium
physical id: 0
capabilities: partitioned partitioned:dos
configuration: signature=09e8dd70
*-volume
description: Windows FAT volume
vendor: SYSLINUX
physical id: 1
logical name: /dev/sdb1
version: FAT32
serial: f6e8-19da
capacity: 14GiB
capabilities: primary bootable fat initialized
configuration: FATs=2 filesystem=fat label=CLR_ISO
*-usbhost:1
physical id: 1
bus info: usb@6
logical name: usb6
version: 5.02
*-storage
description: SATA controller
product: FCH SATA Controller [AHCI mode]
physical id: 11
bus info: pci@0000:00:11.0
version: 40
width: 32 bits
clock: 66MHz
capabilities: storage msi ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=32
resources: irq:28 ioport:f140(size=8) ioport:f130(size=4) ioport:f120(size=8) ioport:f110(size=4) ioport:f100(size=16) memory:feb4d000-feb4d7ff
*-usb:2 UNCLAIMED
product: FCH USB OHCI Controller
physical id: 12
bus info: pci@0000:00:12.0
version: 11
width: 32 bits
clock: 66MHz
capabilities: ohci
configuration: latency=32
resources: memory:feb4c000-feb4cfff
*-usb:3
product: FCH USB EHCI Controller
physical id: 12.2
bus info: pci@0000:00:12.2
version: 11
width: 32 bits
clock: 66MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=32
resources: irq:17 memory:feb4b000-feb4b0ff
*-usbhost
product: EHCI Host Controller
vendor: Linux 5.2.7-816.native ehci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 5.02
configuration: driver=hub slots=5 speed=480Mbit/s
*-usb:4 UNCLAIMED
physical id: 13
bus info: pci@0000:00:13.0
version: 11
width: 32 bits
clock: 66MHz
capabilities: ohci
resources: memory:feb4a000-feb4afff
*-usb:5
physical id: 13.2
bus info: pci@0000:00:13.2
version: 11
width: 32 bits
clock: 66MHz
resources: irq:17 memory:feb49000-feb490ff
*-usbhost
physical id: 1
bus info: usb@2
logical name: usb2
version: 5.02
*-usb
description: Video
product: HP High Definition 1MP Webcam
vendor: Sunplus IT Co
physical id: 1
bus info: usb@2:1
version: 53.64
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-serial
description: SMBus
product: FCH SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 14
width: 32 bits
clock: 66MHz
configuration: driver=piix4_smbus latency=0
resources: irq:0
*-multimedia
description: Audio device
product: FCH Azalia Controller
physical id: 14.2
bus info: pci@0000:00:14.2
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_hda_intel latency=32
resources: irq:16 memory:feb40000-feb43fff
*-isa
description: ISA bridge
product: FCH LPC Bridge
physical id: 14.3
bus info: pci@0000:00:14.3
version: 11
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
configuration: latency=0
*-pci:3
product: FCH PCI Bridge
physical id: 14.4
bus info: pci@0000:00:14.4
version: 40
width: 32 bits
clock: 66MHz
capabilities: pci subtractive_decode bus_master
*-usb:6 UNCLAIMED
physical id: 14.5
bus info: pci@0000:00:14.5
version: 11
width: 32 bits
clock: 66MHz
capabilities: ohci
resources: memory:feb48000-feb48fff
*-pci:1
product: Family 15h (Models 10h-1fh) Processor Function 0
physical id: 101
bus info: pci@0000:00:18.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
product: Family 15h (Models 10h-1fh) Processor Function 1
physical id: 102
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
product: Family 15h (Models 10h-1fh) Processor Function 2
physical id: 103
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
product: Family 15h (Models 10h-1fh) Processor Function 3
physical id: 104
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
configuration: driver=k10temp
resources: irq:0
*-pci:5
product: Family 15h (Models 10h-1fh) Processor Function 4
physical id: 105
bus info: pci@0000:00:18.4
version: 00
width: 32 bits
clock: 33MHz
*-pci:6
product: Family 15h (Models 10h-1fh) Processor Function 5
physical id: 106
bus info: pci@0000:00:18.5
version: 00
width: 32 bits
clock: 33MHz
*-scsi:0
physical id: 1
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: WDC WD10EZEX-60Z
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 0A80
serial: WD-WMC1S1183346
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=10b8ecf4-693d-49c4-b629-faaeff3b187a logicalsectorsize=512 sectorsize=4096
*-volume:0
description: Windows NTFS volume
vendor: Windows
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
version: 3.1
serial: f6d0-c0b5
capacity: 1022MiB
capabilities: boot precious readonly hidden nomount ntfs initialized
configuration: clustersize=4096 created=2012-12-14 10:28:52 filesystem=ntfs label=Windows RE tools modified_by_chkdsk=true mounted_on_nt4=true name=Basic data partition resize_log_file=true state=dirty upgrade_on_mount=true
*-volume:1
vendor: MSWIN4.1
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
version: FAT32
serial: 86fb-0ae6
capacity: 359MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat label=SYSTEM name=EFI system partition
*-volume:2
description: reserved partition
vendor: Windows
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
serial: 106f8e65-95db-4ca5-a3c5-ed7a0759c5f7
capacity: 127MiB
capabilities: nofs
configuration: name=Microsoft reserved partition
*-volume:3
vendor: Windows
physical id: 4
bus info: scsi@0:0.0.0,4
logical name: /dev/sda4
version: 3.1
serial: 341e31a7-10d5-884b-9060-743858d4b247
capacity: 735GiB
capabilities: ntfs initialized
configuration: clustersize=4096 created=2014-04-22 03:07:04 filesystem=ntfs label=OS name=Basic data partition state=clean
*-volume:4
vendor: Windows
physical id: 5
bus info: scsi@0:0.0.0,5
logical name: /dev/sda5
version: 3.1
serial: 3cb99480-61e0-b946-a0c5-624e166a1086
capacity: 3498MiB
configuration: clustersize=4096 created=2019-03-05 23:06:25 filesystem=ntfs label=Win/Linux Shared modified_by_chkdsk=true mounted_on_nt4=true name=Basic data partition resize_log_file=true state=dirty upgrade_on_mount=true
*-volume:5
description: EXT4 volume
vendor: Linux
physical id: 6
bus info: scsi@0:0.0.0,6
logical name: /dev/sda6
version: 1.0
serial: ca5e8bf2-1eda-49c2-ae45-2d03828f17d7
capabilities: journaled extended_attributes large_files huge_files dir_nlink 64bit extents ext4 ext2 initialized
configuration: created=2019-02-06 03:28:44 filesystem=ext4 lastmountpoint=/ modified=2019-08-13 17:31:31 mounted=2019-08-13 17:31:35 state=clean
*-volume:6
vendor: Windows
physical id: 7
bus info: scsi@0:0.0.0,7
logical name: /dev/sda7
version: 3.1
serial: 72a2-0cc0
capacity: 449MiB
configuration: clustersize=4096 created=2014-04-22 16:40:55 filesystem=ntfs modified_by_chkdsk=true mounted_on_nt4=true resize_log_file=true state=dirty upgrade_on_mount=true
*-volume:7
vendor: Windows
physical id: 8
bus info: scsi@0:0.0.0,8
logical name: /dev/sda8
version: 3.1
serial: 14f7-7340
capacity: 349MiB
configuration: clustersize=4096 created=2013-12-03 00:45:30 filesystem=ntfs modified_by_chkdsk=true mounted_on_nt4=true resize_log_file=true state=dirty upgrade_on_mount=true
*-volume:8
vendor: Windows
physical id: 9
bus info: scsi@0:0.0.0,9
logical name: /dev/sda9
version: 3.1
serial: fe7a8807-e2ba-e648-83a6-1b92fde58e63
capacity: 11GiB
capabilities: precious readonly hidden nomount ntfs initialized
configuration: clustersize=4096 created=2012-12-14 10:14:27 filesystem=ntfs label=Recovery Image modified_by_chkdsk=true mounted_on_nt4=true name=Basic data partition resize_log_file=true state=dirty upgrade_on_mount=true
*-scsi:1
physical id: 2
logical name: scsi1
*-cdrom
description: DVD-RAM writer
product: CDDVDW SN-208BB
vendor: hp
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/sr0
version: HD20
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-power UNCLAIMED
description: N/A
product: Standard Efficiency
vendor: NULL
physical id: 1
version: NULL
serial: N/A
capacity: 32768mWh
dmesg does not appear to show any changes when a device is plugged in or out in the rear ports.
Also, when plugged into the rear ports, the system will still boot, but devices plugged into the remaining free ports will not be seen either.
