The instructions in the tutorial shall be good.
Do you also have a motherboard GPU?
Yeah, I hadnāt paid much attention to the onboard graphics before as I always used the NVIDIA but yes that is probably the main reason this failed.
You can pull the latest version of Nvidia from:
https://download.nvidia.com/XFree86/Linux-x86_64/latest.txt
and download the latest version on the list:
Itās just a suggestion if you want to simplify your scripts. Cheers!
Thx! I will incorporate this.
Well, you have to either disable the motherboard GPU or try to utilize both GPUs. Unfortunately Iām not aware of any successful cases.
Iāve disabled the motherboard GPU, as I never use it anyway.
If you disabled it, it shall work.
BTW, how do you do that?
@doct0rHu I disabled it from the BIOS, it had an option to permanently disable. Iām assuming it worked as I did ālshw -short | grep -i displayā and it only showed my NVIDIA card.
Thatās great because some people cannot find such option in their BIOS and cannot easily disable motherboard gpu.
After i did the basic nvidia install tutorial i canāt run nvidia drivers (outputs i post here). Steps that you describe in your post help me fix launch nvidia-settings
and nvidia-smi
, but despite the fact that the discrete card is much more powerful than the built-in, image became very laggy (for example - event just page scroll in firefox work with ~5FPS framerate).
And glxinfo output look not like you
> glxinfo| grep OpenGL
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: llvmpipe (LLVM 8.0, 256 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 19.2.0-devel
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.1 Mesa 19.2.0-devel
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 19.2.0-devel
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
@Akiyamka
It seems your system is running within a virtual machine. To be honest, Iām not sure whether the tutorial is relevant to your case.
clear linux is not in a virtual machine, it is installed as as system on my laptop. But I understand why you thought that. If you look at last strings you see that now used driver - mesa. Mesa is an open source software implementation of OpenGL. Maybe itās somehow use virtual machine internally for emulation.
This is really strange.
When do you downloaded the scripts? Because I was updating it on July 2nd ( US Eastern Time).
And would you uninstall it and have another try with the updated scripts? There are some changes from Clear Linux official tutorial and I have incorporated them
Also, if you would reinstall the driver, could you also show me the output of lspci before and after installation? ( In my case, before installation itās using the library from nvidafb.)
For some raisin I canāt even see the download or am I just that blind?
Sorry, I forgot to add the link after I updated the post. You can find it at the top now.
You right, i used old script.
Now I rollback all changes, and try again with new updated script.
Here my system state before i run scripts:
Nvidia driver is not used:
> glxinfo|egrep "OpenGL vendor|OpenGL renderer*"
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) UHD Graphics 620 (Kabylake GT2)
My cards:
> lspci | grep NVIDIA && lspci | grep VGA
01:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX150] (rev a1)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:13.0 Non-VGA unclassified device: Intel Corporation Sunrise Point-LP Integrated Sensor Hub (rev 21)
Attention to NVIDIA - just ā3D controllerā without āVGAā substring.
In your example you uselspci | grep -i vga
command and see nvidia card as āVGA compatible controllerā. Maybe that important.
In accordance with the guidelines here, I expanded the blacklist
> cat /etc/modprobe.d/nvidia-disable-nouveau.conf
blacklist nouveau
blacklist nvidiafb
blacklist rivafb
options nouveau modeset=0
Letās make sure that there are no pieces from nvidia drivers
> lsmod | grep ^nvidia
[nothing]
> nvidia-settings
command not found
> nvidia-smi -a
command not found
OK, letās do it.
/etc/X11/xorg.conf.d/20-optimus.conf
with content from post above> cat /etc/X11/xorg.conf.d/20-optimus.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0.0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Default
file> cat /etc/gdm/Init/Default
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
pre_install.sh
)> sudo ./install.sh
ā³ Locating NVIDIA-Linux-x86_64-<VERSION>.run ...
ā³ Configuring dynamic linker configuration ...
Updating dynamic linker run-time bindings and library cache...
ā³ Configuring Xorg to search for additional module ...
ā³ Installing NVIDIA proprietary Driver now ...
If the installation is successful, GUI may automatically start.
Please run the post_install.sh to validate that the nvidia kernel modules are loaded.
The version of the driver is 430.26
Press any key to continue...
Nice itās my driver. Press anykey
verifying archive integrity... OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 430.26
post_install.sh
sudo ./post_install.sh
ā³ Making sure NVIDIA kernel modules are loaded ...
nvidia_drm 45056 1
nvidia_modeset 1114112 1 nvidia_drm
nvidia 18784256 1 nvidia_modeset
ā³ Verifying the integrity of OpenGL library files ...
Verifying version 30210
Verifying files
...100%
Starting download of remaining update content. This may take a while...
...576%
Adding any missing files
Missing file: /usr/lib64/libEGL.so
fixed
Missing file: /usr/lib64/libEGL.so.1
fixed
Missing file: /usr/lib64/libEGL.so.1.0.0
fixed
Missing file: /usr/lib64/libGL.so
fixed
Missing file: /usr/lib64/libGL.so.1
fixed
Missing file: /usr/lib64/libGL.so.1.2.0
fixed
Missing file: /usr/lib64/libGLESv1_CM.so
fixed
Missing file: /usr/lib64/libGLESv1_CM.so.1
fixed
Missing file: /usr/lib64/libGLESv1_CM.so.1.1.0
fixed
Missing file: /usr/lib64/libGLESv2.so
fixed
Missing file: /usr/lib64/libGLESv2.so.2
fixed
Missing file: /usr/lib64/libGLESv2.so.2.0.0
fixed
Inspected 260 files
12 files were missing
12 of 12 missing files were replaced
0 of 12 missing files were not replaced
Calling post-update helper scripts.
none
Repair successful
š Installation completed!
Ok, now I reboot
After reboot i saw black screen with blinking cli cursor. After ~10 sec blinking stoped, and system totally freeze. So i reboot again, go to clrl+2 session and collect some info:
nvidia_drm 45056 0
and journalctl output about last boot.
journalctl gist
I think the reason why prime doesnāt work in GDM issue. I need to install gdm-prime instead gdm or use x-run with another window-manager.
Now the problem is that I did not find gdm-prime for Clear* Linux and without any ideas where to get it
I am finding the same results with the same Nvidia GPU.
My next step will be to run all these steps and use lightdm instead of gdm and see.
pre_install.sh
tries to install DKMS for you and itās harmless to run it because swupd
will just tell you itās already installed. Then pre_install.sh
updates the clr-boot-manager
and disable nouveau
driver. Youāve manually disabled it so itās okay to skip this script.install.sh
donāt have any output after you successfully installed the driver. The reason is that usually once the driver is installed, the graphical display manager such as gdm
will starts automatically and you are no longer in tty
./etc/X11/xorg.conf.d/20-optimus.conf
and /etc/gdm/Init/Default
come from NVIDIAās documentation and I didnāt find it anywhere else online and I cannot test this because I donāt have optimus
. The documentation is available here.post_install.sh
looks correct.Before NVIDIA driver is installed, the output of glxinfo
and lspci
indicates that your system is using your on-board GPU. The output shall looks like this
⯠glxinfo|egrep "OpenGL vendor|OpenGL renderer*"
OpenGL vendor string: nouveau
OpenGL renderer string: NV132
Notice the nouveau
driver is used, and that is what we blacklisted in modrprobe
Iāve did some search online and it says that itās normal to have some NVIDIA GPU who supports OPTIMUS to be identified as 3D Controller
instead of VGA Compatible Controller
. Because theyāre not really GPU, but just a rendering unit connecting to onboard GPU via an adapter. (Not sure whether this is correct.)
ArchWiki has this post(PRIME - ArchWiki) that might be helpful. In particular, Iāve forked nvidia-xrun
so that itās consistent with the official tutorial on installing NVIDIA driver. The fork is available here.
Please refer to ArchWiki and the original repository for more detailed instructions. I cannot test it.
This is also what I had after I installed the NVIDIA driver but when I connect the display to motherboard GPU.
So in other word it confirmed my guess that your NVIDIA GPU is never used by the system, though the modules ARE installed given the output of lsmod
Check my forked version of nvidia-xrun
