I found some documentation to try and fix the issue and followed it exactly:
https://docs.01.org/clearlinux/latest/guides/maintenance/fix-broken-install.html
Here is what I see:
clrlinux@clr-live~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 2.2G 1 loop
sda 8:0 0 698.7G 0 disk
├─sda1 8:1 0 142M 0 part
├─sda2 8:2 0 244M 0 part
└─sda3 8:3 0 698.3G 0 part
sdb 8:16 0 2.7T 0 disk
├─sdb1 8:17 0 128M 0 part
└─sdb2 8:18 0 2.7T 0 part
sdc 8:32 1 29.5G 0 disk
├─sdc1 8:33 1 2.4G 0 part
└─sdc2 8:34 1 100M 0 part
sr0 11:0 1 1024M 0 rom
clrlinux@clr-live~ $ sudo mount /dev/sda3 /mnt
clrlinux@clr-live~ $ cat /mnt/usr/lib/os-release
NAME="Clear Linux OS"
VERSION=1
ID=clear-linux-os
ID_LIKE=clear-linux-os
VERSION_ID=30770
PRETTY_NAME="Clear Linux OS"
ANSI_COLOR="1;35"
HOME_URL="https://clearlinux.org"
SUPPORT_URL="https://clearlinux.org"
BUG_REPORT_URL="dev@lists.clearlinux.org"
PRIVACY_POLICY_URL="http://www.intel.com/privacy"
clrlinux@clr-live~ $ sudo swupd repair --picky --path=/mnt
Diagnosing version 30770
Checking for corrupt files
...100%
Starting download of remaining update content. This may take a while...
Adding any missing files
...100%
Repairing corrupt files
-> Hash mismatch for file: /mnt/proc -> not fixed
-> Hash mismatch for file: /mnt/sys -> not fixed
...100%
--picky removing extra files under /mnt/usr
REMOVING /usr/share/fonts/truetype/liberation/.uuid
REMOVING /usr/share/fonts/truetype/.uuid
REMOVING /usr/share/fonts/terminus/.uuid
REMOVING /usr/share/fonts/roboto/.uuid
REMOVING /usr/share/fonts/noto/.uuid
REMOVING /usr/share/fonts/noto-emoji/.uuid
REMOVING /usr/share/fonts/noto-cjk/.uuid
REMOVING /usr/share/fonts/cantarell/.uuid
REMOVING /usr/share/fonts/adobe-source-code-pro/.uuid
REMOVING /usr/share/fonts/X11/misc/.uuid
REMOVING /usr/share/fonts/X11/encodings/.uuid
REMOVING /usr/share/fonts/X11/Type1/.uuid
REMOVING /usr/share/fonts/X11/TTF/.uuid
REMOVING /usr/share/fonts/X11/OTF/.uuid
REMOVING /usr/share/fonts/X11/75dpi/.uuid
REMOVING /usr/share/fonts/X11/100dpi/.uuid
REMOVING /usr/share/fonts/X11/.uuid
REMOVING /usr/share/fonts/.uuid
Inspected 212442 files
2 files did not match
0 of 2 files were repaired
2 of 2 files were not repaired
18 files found which should be deleted
18 of 18 files were deleted
0 of 18 files were not deleted
[FATAL] cbm (../src/bootman/bootman.c:L430): Cannot determine boot device
[FATAL] cbm (../src/bootman/update.c:L144): Failed to set the default kernel to: /mnt//usr/lib/kernel/org.clearlinux.native.5.2.8-818
Repair did not fully succeed
Any help would be much appreciated.
