I installed it from the live desktop. There was no errors, it installed successfully, but after rebooting there’s no option for clear linux os, there is only built-in EFI shell. Please help
You could try a few things
First can you get clear Linux to boot from the UEFI shell
Here are the commands I used to boot my system
~fs0:
fs0: Should put you in the boot file system if that doesn’t work you could try fs1:, fs2:, etc
~ls
You will know you are in the right file system if ls show the directories
efi
loader
Running the next 3 commands should boot clear Linux
~cd efi
~cd boot
~boot64.efi
Second
If you haven’t already go into your computers bios settings and see what it displays for your boot order and what boot options are available.
Third
you could use the live USB to examine the contents of the installed system to see if anything was written to disk. Using the default install settings clear Linux should have installed a small boot partition and used the rest of the drive for the root filesystem.
Finally
It probably won’t turn out to be useful information but could you post the manufacturer and model of your motherboard.
