Installer is showing no media found for installation
But i can use every file using file manager
The community would need more details about your issue to help you. Anyway, I had a similar issue. Check it here You can check if this is your issue also.
If you are nos a experienced user, I believe that you should not do this procedure.
Tried that but it didn’t helped
Please if someone can help
had the same problem with Ventoy. With balenaEtcher it worked
