I add the printer in the Settings, but I can’t print because /pathto/rastertogutenprint.5.2 not found.
Printer connected to PC with Ubuntu 18.04.3 and shared to local network. From Windows no any problem found.
What can I do?
Thanks
What can I do?
Thanks
FIle a detailed bug on github that includes the exact error output. Include details like type of printer, relevant dmesg/journalctl output, error messages etc.
LocalNetwork looks:
ClearLinux → router <-Ubuntu <-printer (EPSON Stylus-Photo-R220)
Step to reproduce:
LOGS:
And screenshot when try to print anything
And after send to print:
Mar 16 03:59:17 clr gedit[2514]: no pages to print
Seems like we updated gutenprint to 5.3, Can you restart cupsd or reboot, and try again?
After stop/start and reboot error repeated:
root@clr/home/aleksei/Documents # systemctl status cupsd > status.txt
root@clr/home/aleksei/Documents # cat status.txt
● cupsd.service - CUPS Scheduler
Loaded: loaded (/usr/lib/systemd/system/cupsd.service; disabled; vendor preset: disabled)
Active: active (running) since Mon 2020-03-16 04:46:23 +07; 1min 4s ago
TriggeredBy: ● cupsd.socket
Docs: man:cupsd(8)
Main PID: 849 (cupsd)
Tasks: 1 (limit: 18986)
Memory: 4.4M
CGroup: /system.slice/cupsd.service
└─849 /usr/bin/cupsd -l
Mar 16 04:46:23 clr systemd[1]: Started CUPS Scheduler.
Mar 16 04:46:24 clr cupsd[849]: Stylus-Photo-R220: File "/usr/lib/cups/filter/rastertogutenprint.5.2" not available: No such file or directory
Mar 16 04:46:24 clr cupsd[849]: REQUEST localhost - - "POST / HTTP/1.1" 200 363 Create-Printer-Subscriptions successful-ok
when send to print
I’m unsure of what to fix, at this point. You can possibly symlink the missing 5.2 filter to the 5.3 one in the folder and try that.
Symlink not help, get another but similar errors with other filters (
For me I see 2 methods:
Thanks.
though this topic is 3.5 years old, i ran into the same problem and it seems unsolved in this thread. Therefore, try this solution if you come across this problem:
