Version 33070 problems
The need for my hard restarts with this AMD issue black screen frozen mouse cursor etc. the keyboard was also frozen so never could use terminal consul but what really was scary on my restart I could not access bios,keyboard was still frozen and I saw all the leds on my R9 fury gpu were out I couldn’t access my windows 10 installation that was on a nvme card Which I disable when using CL. I had to short the jumpers to clear cmos and then I was able to access bios again. That’s why I think the update affected video card and bios and not in a good way.
Before your keyboard got frozen, if you quickly switch to tty2, everything would be fine.
I uninstalled clear linux because of this. Moved to Ubuntu now.
33100 update fixes the issue for me I use AMD R9 Fury gpu on my PC thanks for the fix!
33100: mesa 20.1+415.g094c7646a3a-248 → 19.3+5425.1e7c1f4224-247
https://cdn.download.clearlinux.org/releases/33100/clear/RELEASENOTES
if you are running Intel BOXNUC8i7HVK1 Hades Canyon systems I can confirm it is now safe execute
sudo swupd autoupdate --enable
